Whats the difference ??
Q
« on: 18 Feb 2004, 05:07 pm »
Can someone tell me the difference between the BG Neo 8's and the Neo's that VMPS uses on their latest designs?  They look very similar but have  a slightly different front panel.  Interesting too that the VMPS drivers are crossed over at 166Hz...much lower than the BG's are rated for.
Danny Richie
« Reply #1 on: 19 Feb 2004, 03:46 pm »
The planars used by VMPS are capable of playing lower than the BG Neo 8, but not as high.
A closer comparison would be the VMPS panel to the new BG Neo 10. The Neo 10 is 5" by 10" and capable of playing down to 100Hz but it also does not play as high as the Neo 8.
The width of the panel also determines the off axis response.
Playing the planars down low (down to the 200Hz range or so) has advantages and disadvantages.
The advantage is that it can bring a lot of speed, detail and quickness down into that range in a way that exceeds the ability of larger woofers.
The disadvantages are limited air moving capability down into a range that at higher volume levels needs a driver capable of moving air to have an impact.
A crossover right in the midrange area or lower midrange area (around the 200Hz point) is tough. Integration is not easy especially from dissimilar drivers.
Upper vocals, for instance, coming from a line source of planars that will loose only 3db per doubling of distance, having to blend with lower vocals produced by one woofer that will loose 6db per doubling of distance becomes very distance dependant and a real compromise at best.
After carefully listening to the Alpha LS with crossover points ranging from 600Hz to 1500Hz it was felt that crossing in the 1000 to 1200Hz region yielded the best overall sound and allowed for the greatest power handling too.
tomahack
« Reply #2 on: 19 Feb 2004, 05:06 pm »
Any ETA for the new Neo 10 Danny?
Thanks.
Danny Richie
ETA
« Reply #3 on: 19 Feb 2004, 05:11 pm »
It has not yet been determined if BG will release it to the public or not. It may be something that they use exclusively.
clyde
« Reply #4 on: 20 Feb 2004, 02:07 am »
Any idea where BG is using the Neo10?   The new version of their Radia floorstanding speaker has a Neo ribbon for the first time.
BG has dropped all mention of OEM drivers from their reworked Web site (bgcorp.com).  Hopefully that is not a bad sign for the continued availability of their drivers to other manufacturers and the DYI community.
