Tower of Power
0 Members and 1 Guest are viewing this topic. Read 3770 times.
  • The Demo is Everything!
    • http://www.bryston.com
Tower of Power
« on: 25 Jun 2010, 09:22 pm »
James – todays install
ONE AWSOME TOWER OF POWER
Ashley Plettell
Smiths Custom Audio Video inc.
Alberta, Canada
PS - James,
Speakers are Paradigm Signature S-2, C-3, Sig ADP, and Sig Servo 15 each speaker has its own 3BSST2 Bridged on it WOW what awesome dynamic Range this has to be no I can honestly say it is the best sounding theatre in southern Alberta and it was all Help to Bryston and Smiths... we have made Magic Happen here....
« Last Edit: 25 Jun 2010, 10:37 pm by James Tanner »
Laundrew
Re: Tower of Power
« Reply #1 on: 25 Jun 2010, 09:27 pm »
 :o :!:
Be well...
Ryanz
Re: Tower of Power
« Reply #2 on: 25 Jun 2010, 09:51 pm »
I'm in love. :drool:
vegasdave
Re: Tower of Power
« Reply #3 on: 25 Jun 2010, 10:43 pm »
 :o  :drool:
JRace
  • Greetings one and Everyone!
Re: Tower of Power
« Reply #4 on: 25 Jun 2010, 10:48 pm »
Is that a VCR I see at the top :scratch:
Re: Tower of Power
« Reply #5 on: 25 Jun 2010, 11:36 pm »
NO -  it's the new Bryston 8-track :D
james
vegasdave
Re: Tower of Power
« Reply #6 on: 26 Jun 2010, 12:20 am »
james
 :lol:
Ryanz
Re: Tower of Power
« Reply #7 on: 26 Jun 2010, 12:36 am »
james
Wicked!  :rock: Way to represent James!
Laundrew
Re: Tower of Power
« Reply #8 on: 26 Jun 2010, 01:16 pm »
james
Mmmm... True analogue.  :drool:
 :wink:
Be well...
werd
Re: Tower of Power
« Reply #9 on: 26 Jun 2010, 03:15 pm »
It would be nicer if the stack was zebra
Watson
Re: Tower of Power
« Reply #10 on: 26 Jun 2010, 03:28 pm »
Looks nice!
Serious question: is that enough ventilation for all that Bryston gear? Would he have to only run it with the glass door open, or would it be safe to use with the glass door closed?
drummermitchell
Re: Tower of Power
« Reply #11 on: 26 Jun 2010, 03:55 pm »
I'd like them to swap that monster conditioner with a Torus and see what they think.
srb
Re: Tower of Power
« Reply #12 on: 26 Jun 2010, 04:07 pm »
I'm guessing the 3BSST2 was chosen over the 7BSST2 for a cost savings of ~ $4K, which of course is not a small amount of money.
But in the context of a very expensive home theatre, if they should decide to change speakers at some point, they would be limited to choosing 8 ohm models only.
Also on the Bryston website the specifications say "30,000 MFD per channel" for both amplifiers.  Does this mean the 7BSST2 would only have 30,000 MFD but the 3BSST2 bridged would have 60,000 MFD?
What would be the sonic difference between the 3BSST2 bridged versus the mono 7BBST2 besides the obvious difference of 400W versus 600W?
Re: Tower of Power
« Reply #13 on: 26 Jun 2010, 04:16 pm »
Hi Steve,
The amplifier 'sees' 1/2 the impedance in mono so it is not a good idea for speakers rated below 4 ohms to use a 3B in bridged mode as it would start to current limit.  The subwoofer though has what we call a very easy 'duty cycle' so a bridged 3B is no issue at all.
I think the MDF figures must be incorrect - I will check.
james
« Last Edit: 28 Jun 2010, 07:48 pm by James Tanner »
Re: Tower of Power
« Reply #14 on: 26 Jun 2010, 04:18 pm »
Looks nice!
Hi Watson,
Generally a single rack space (1 3/4 inches) is adequate between the amps but a lot will have to do with the stand.  If it has an open back then no issue - if not the amps could get hot under very heavy loads.
james
werd
Re: Tower of Power
« Reply #15 on: 26 Jun 2010, 05:09 pm »
I owned both (at the same time). Well lets just say the Monster cable was boxed and stored.... hehe
Mag
Re: Tower of Power
« Reply #16 on: 26 Jun 2010, 06:22 pm »
Yep, I unboxed it! I know the Torus is probably better than the AVS 2000, but is it 10 X better, Werd? :wink:
werd
Re: Tower of Power
« Reply #17 on: 29 Jun 2010, 08:19 pm »
Hi Mag
don't read to far into that comment. The AVS 2000 is a great starting point and takes you into the same ball park as the Torus. Having said that the Torus is better (considerably). They both are about the same price new.
