0 Members and 1 Guest are viewing this topic. Read 3315 times.
No, I've had one for just under a year and have been using it with high efficiency, 95-96 dB speakers, dead silence. I would contact the owner there Dejan Dobrin and ask his advice. The web address: http://www.dayens.rs/eng_about.html
I am surprised that you are having this problem but wouldn't contacting Dayens or the north american importer be of more help than I could possibly be.
My experience with this product has been overwhelmingly positive. In addition to the review on 6Moons, I have been contacted by a few people who have the product and the unanimous opinion has been positive. This is the first mention of hum w/ the Ampino I have heard.If it were mine I would open it up and check to see if there is anything lose or rattling. Good luck.
If it is indeed transformer vibration hum, sometimes it can be remedied by loosening the bolt through the torroidal transformer, rotating the transformer a bit one way or the other (wire slack permitting), then retightening. This was also the solution in a recent thread on ACI subwoofer transformer hum. Steve
Sorry, I was hoping that might work. While you're waiting for a response from the manufacturer or importer, have you tried plugging it into a different AC circuit? If there's not a different circuit available in the room, maybe you could use an extension cord plugged into a different circuit in another room. Steve
