Best speaker terminations with AVA
0 Members and 1 Guest are viewing this topic. Read 7961 times.
TjMV3
Re: Best speaker terminations with AVA
« Reply #40 on: 26 Jun 2010, 05:07 pm »
I do not use bananas at the speaker end at all when I do this, just at the amp.
Wayner
Do you prefer to use barewire at the speaker terminals?
I have always preferred bare wire at the speaker terminals.
jhm731
« Reply #41 on: 26 Jun 2010, 06:48 pm »
I agree that banana plugs are probably the best connectors for the AVA Insight 440H's binding posts.
When I tried to tighten down on spades with the AVA Insight 440H I had,
the plastic nuts started slipping.
Wayner
« Reply #42 on: 26 Jun 2010, 09:49 pm »
You don't need wire gauges that you could run your stove on!
W
Wayner
« Reply #43 on: 26 Jun 2010, 09:52 pm »
It depends on the speaker. For the usual single set, I use the duals. For a couple of the bi-wireable speakers that I have, then I like to run the wire thru the terminals. My Martin Logan reQuests are unique in that they are bi-wired and use dual bananas at both ends.
Wayner
martyo
« Reply #44 on: 27 Jun 2010, 12:28 pm »
Some folks are dangerous with tools.
jhm731
« Reply #45 on: 27 Jun 2010, 06:00 pm »
Yes, the hand is a very powerful tool.
