ForceXL Connections
0 Members and 1 Guest are viewing this topic. Read 1601 times.
Kevin O'Toole
  • Guest
ForceXL Connections
« on: 22 Jun 2010, 11:09 am »
I connected the left and right pre-outs of a Musical Fidelity X-150 to the left and right inputs of a ForceXL - and then read the directions. Do I need a Y connector or will this set up do?
srb
Re: ForceXL Connections
« Reply #1 on: 22 Jun 2010, 02:02 pm »
You have hooked it up correctly.  The Left and Right line level inputs are for connecting the Left and Right pre-outs from a preamplifier or integrated amplifier.  No Y connector needed.
Mike Dzurko
« Reply #2 on: 22 Jun 2010, 08:26 pm »
You got it, thanks Steve!
Kevin O'Toole
  • Guest
« Reply #3 on: 22 Jun 2010, 10:00 pm »
Thank you both very much. I found a (barely, if at all) used ForceXL and have had it for a week or so. Along with the foam plugged SapphireXLs I'm having a ball. I just bought a Radio Shack meter and will do some serious configuring when it has run in a little more. It's sounding pretty good now, though. The hi-fi press makes it seem like integrating a sub is one of the most difficult tasks imaginable!
The system is: a week old OPPO 83SE, SapphireXLs with a ForceXL sub, a Musical Fidelity X-150 and a Cambridge Audio DACMagic handling a fiber optic signal from an AirPort Express.
