Looking for Pre-Amp/DAC With SPDIF/COAX/USB
0 Members and 1 Guest are viewing this topic. Read 3358 times.
capwkidd
« on: 22 Jun 2010, 03:41 am »
....and if it could do DTS/DD that would be great also :)
Any suggestions?
kip_
Re: Looking for Pre-Amp/DAC With SPDIF/COAX/USB
« Reply #1 on: 22 Jun 2010, 03:47 am »
Maverick D1, $199
http://www.mavaudio.com/
eclein
capwkidd
« Reply #3 on: 22 Jun 2010, 04:01 am »
The Maverick Looks interesting.... any reviews?
Maverick D1, $199
eclein
Ramón
« Reply #5 on: 23 Jun 2010, 12:44 am »
I would get an AV Receiver with preouts. The older Harman models have quite decent DAC sections build in wich can compete with the DAC´s in your pricerange you´re looking for imo. They´re well known for t´s stereo performance, at least over here in germany. Even if you don´t use the rear channels you get a powerful remote controlable stereo amp / preamp and DTS / AC3 capable DAC for cheap.
This one is a incredible bargain, with flaws but insanely cheap http://cgi.ebay.com/Harman-kardon-AVR-435-7-1-channel-Receiver-Good-Cond-/320538587552?cmd=ViewItem&pt=Receivers_Tuners&hash=item4aa196b1a0
WerTicus
« Reply #6 on: 15 Jul 2010, 02:00 pm »
I'm looking for a cheap and cheerful DAC that runs on 220v and can take the optical from my PS3 and output balanced analogue XLR? (I know not exactly typically cheap) :)
eclein
« Reply #7 on: 15 Jul 2010, 02:07 pm »
http://www.grantfidelity.com/site/Grant_Fidelity_Tube_DAC-09
I got one of these^^^ love it..I use a PS3 toslink optical output to the DAC to an integrated amp, not sure if it fits your power requirements though..check it out..FWIW
srb
« Reply #8 on: 15 Jul 2010, 03:22 pm »
Neither the Maverick D1 or the Grant Fidelity DAC-09 have balanced XLR outputs.
The Cambridge Audio DacMagic has balanced XLR outputs and uses an external 12VAC @ 1.5A power supply.  The unit should be sold with a suitable 220V input supply in your country or a proper replacement 220VAC input supply could be sourced locally.  The DacMagic retails for $429 US and can be found for ~ $300 US or less used.
The Citypulse DAC DA7.2x II has balanced XLR outputs, 115V/230V dual voltage IEC input and remote control, and sells for $425 US.
mrhyfy
« Reply #9 on: 15 Jul 2010, 03:27 pm »
I've got the matrix Mini dac.  Sounds great,,has volume control and XLR outs. see link
http://www.head-fi.org/forum/thread/441960/matrix-mini-i-balanced-dac-hp-amp
