Could a VPC-1 be used in reverse, as an output selector?
0 Members and 1 Guest are viewing this topic. Read 2159 times.
JEaton
I'm talking about running a single input into the output jacks and then running two outputs from the input jacks?  Say in a system with a single source component and both a headphone amp and power amp, or maybe two power amp/speaker combos that you wanted to switch between?
CIAudio
Re: Could a VPC-1 be used in reverse, as an output selector?
« Reply #1 on: 21 Jun 2010, 07:30 pm »
No...to do this, you would have to cut the internal circuit traces and rewire the input/output.
