0 Members and 1 Guest are viewing this topic. Read 20850 times.
Its a relay volume control and source selector. Some guy from China sells them over on DIYaudio. It has a remote and the small board has a digital display.
Can anyone recommend a good single transformer for the build?
I'm also a bit confused regarding the Fullwave-Voltage-Doubler Rectification versus the Fullwave-Bridge Rectification. I've read through the post on the TubeCad journal and the Janus Rev A book, but I'm still a little nebulous as far as why it would be desirable.
I got those big hulking Dayton caps but it seems like the voltage is too low for line-stage config from the spec sheet in the manual
On the All in One board you are able to mount the tube sockets on the top side of the board and all the other components on the bottom. You must be careful about the orientation of the polarised caps, and the regulator pins need to be twisted 180 degrees, but other then that it's pretty simple.
In a star ground scheme, does every ground point on every input/output jack, volume pot, selector switch and capacitor switch have a seperate wire attaching it to the ground lug on the PCB?
