0 Members and 1 Guest are viewing this topic. Read 6986 times.
The SB Touch needs to use the SB Server running on your computer to play music. If you want to stream 24/96 with the minimum of problems, I suggest you run an Ethernet cable from your computer to the Touch.
anybody using this programhttp://http://vortexbox.org/
Once VortexBox has been loaded on an unused PC, it will automatically rip CDs to FLAC and MP3 files, ID3 tag the files , and download the cover art. Vortexbox will then serve the files to network media players such as Logitech Squeezebox, Sonos, or Linn.
Ok I did download Vortexbox but had trouble unzipping it and installing it.So I did download Exact Copy, I want to make sure that I get the beatquality rips.DO I have to have SB server? I thought the SB would access my laptopthrough my home network w/o any server software.I bought a Seagate 500G portable drive to attach to my HP laptop,reading the posts over at the SB forum they say the Seagate willwork if you want to hook it up directly to the SB Touch also.Dazed and COnfused Jerry
