0 Members and 1 Guest are viewing this topic. Read 11378 times.
Audioengine (there is a thread here on AC)
I'm curious about the Yamaha studio models, they are certainly not expensive and the few user reviews that i read rate them very highly, they should compete with more expensive speakers like Adam Audio, Dynaudio, Spendor and alike..
I have a single Yamaha MSP3 monitor that I use in mono in my "Super Shower Radio" bathroom system. It only has a 20W amp (not bi-amplified), 4" woofer and 3/4" aluminum dome tweeter, and is fairly compact (5-11/16"W x 9-5/16"H x 6-9/16"D). It sounds excellent at all volumes, whereas my bedroom powered speakers, the Kanto iPair5, don't fully "wake up" and don't have enough treble at very low volumes. Bi-amplification in itself does not guarantee great sound. The Yamaha replaced a KRK Rokit 5 monitor, and to my ears outperformed it, even though the specs for the KRK on paper would tell you otherwise (more powerful bi-amplification, 5" woofer, 1" soft dome tweeter, larger cabinet). The extra bass that the KRK generated was boomy, even with LF attenuation and trying different placements. I have not compared these to the Audioengine 5, but I think there may be some value in having a monoblock amplifier in each speaker (The Audioengines have a stereo amp in one speaker and a speaker cable to the other speaker). Using a studio monitor like the Yamaha has two small disadvantages:1. Must run the left and right line level interconnects separately to each monitor2. No single stereo level control. You would have to use the volume control on the computer or adjust both front baffle level controls to change volume. The advantages of the Audioengine are:1. Single left/right interconnect is run to one speaker2. Has a stereo level control on the front controlling both speakers3. Has a USB charging port for the iPod and a rear panel AC outlet to plug in an Airport Express The Yamaha MPS3 sells for $150 -$165 each, or $300 - $330 a pair. Steve
Bi-amplification in itself does not guarantee great sound. The Yamaha replaced a KRK Rokit 5 monitor, and to my ears outperformed it, even though the specs for the KRK on paper would tell you otherwise (more powerful bi-amplification, 5" woofer, 1" soft dome tweeter, larger cabinet). The extra bass that the KRK generated was boomy, even with LF attenuation and trying different placements.adjust both front baffle level controls to change volume.
