0 Members and 1 Guest are viewing this topic. Read 4761 times.
Forget the theory and the name brands for a moment. Set the volume control to your normal listening level and leave it there for the test. Listen to music on the eight ohm tap. Pause the music like you're playing musical chairs (leave the volume control alone). Switch to the four ohm tap and listen again.The tap that sounds the loudest and/or has the loudest bass is the one to use. If you hear no difference then leave it at eight. It's that easy.Now you can ponder the theory. Have fun.
Interesting point Bob. I never heard that rule about output transformers before, but since there are a so many amplifier designs out there I suppose we should cover all of the bases. I know for sure that when you press "pause" on your CD player there will be no audio signal flowing through the amplifier and therefore, no chance of damaging your output tube(s) due to power reflection. In other words, the amplifier should be quite capable of idling unloaded with no audio signal. Mine suffer no damage under this condition.I would not turn the amplifier off to perform this simple A/B test because you would have to wait too long for the amp to warm back up to the same playing condition. Be careful not to touch the hot speaker lead to anything other than the other positive tap when you switch taps and everything will be fine.
The problem is that even with no signal you have an energized primary and an unloaded secondary. This has the potential to set up an oscillation in the output tranny and can burn out the tranny. The output tubes aren't affected, but the tranny wiring is. Most tube amp manufacturers recommend NOT letting the amp idle without a load for this reason.
I can't recall ever seeing that warning before Bob, but thanks for heads up. I'll keep that in mind if I ever disconnect for more than a few minutes.I probably should have mentioned that I use banana plugs on my speaker cables. Changing xformer taps is so easy that it takes more time to get my butt up from the listening chair than to switch the taps.
Interesting point Bob. I never heard that rule about output transformers before, but since there are a so many amplifier designs out there I suppose we should cover all of the bases. I know for sure that when you press "pause" on your CD player there will be no audio signal flowing through the amplifier and therefore, no chance of damaging your output tube(s) due to power reflection. In other words, the amplifier should be quite capable of idling unloaded with no audio signal. Mine suffer no damage under this condition.I would not turn the amplifier off to perform this simple A/B test because you would have to wait too long for the amp to warm back up to the same playing condition. Be careful not to touch the hot speaker lead to anything other than the other positive tap when you switch taps and everything will be fine.Also, Ken, remember that an eight ohm tap is not exactly eight ohms just like an eight ohm speaker is not exactly eight ohms. For example, I think my amplifier taps are closer to 6 and 3 ohms even though they say 8 and 4.The louder, more lively and energetic tap is the one that delivers the power most efficiently to your speaker, and that's probably all that really matters.
