0 Members and 1 Guest are viewing this topic. Read 16447 times.
CAT5 or CAT6 pre-made cables are very inexpensive these days. Take a look at monoprice or PartsExpress. Under $10.00 for 50 ft. While maybe not the best quality, they are better than having a radio transmitter operating inside your music source.A few years ago I bought a 500' spool of outdoor UV rated CAT5e, a crimper and quite a few connectors. I hard wired from my router in my top floor to the basement. I ran more leads through the basement to my son's room so he could play WOW without drops. I recently ran a couple more to the media room for the SB and a Blu-Ray/Netflix player.Wi-Fi is convenient but a bit noisy and slow for 24/96 audio files.
I guess I have some experimenting to do to prove to myself one way or another. I currently run my Touch into my router via ethernet and then WiFi from my laptop. Sure I could run an ethernet from my laptop to my router, just a lot easier to not do so as I sit on the couch 12' away.I guess I haven't bothered with any other configuration because since getting the Touch, I have found my AppleLossless tracks indistinguishable from CDs when fed into my DAC.
Wayne,Why is it that with all the cable hoopla in the audio world no one (that I know of) is making "audiophile" ethernet cables? Does it truly not matter? We all make such a big deal out of all our other connections.
You really should run hard wired from the computer to the router. The laptop should be in a different room to remove any hard drive noise and fan noise from the computer. We aren't even going to start about the switching power supplies used by laptops polluting the AC line near your system and the RFI they produce.
Thanks for the comments, Mike.For many years, I had not heard an outboard DAC that sounded better to me than the modded analog output of a SqueezeBox. The analog modded Touch, when used with a good linear power supply, still sounds better than most under $1,000.00 outboard DACs.The Eastern Electric Mini-Max DAC was the first DAC I heard I could honestly say sounds better. Coupled with a digital modded Touch, it sounds great! Mods will soon be finalized for the EE DAC to take it to an even higher level.I have not had a chance to hear the W4S of the Bel Canto DAC 3, but I believe the digital modded Touch will make the sound out of them even better.
I keep picking up more in recordings that I never noticed before that I've heard hundreds of times.Listening to Sting's tune "All This Time" right now and it is playing tricks on me. I'd swear there is another set of speakers hiding somewhere. Crazy.Thanks again Wayne.
Admittedly unplugging the screen is a pretty drastic tweak. Its certainly not for everybody. I'm working on a way to do it in software so you don't actually have to take the device apart. I actually have it working, and its even more effective than unplugging the sreen (it shuts down the whole video subsystem), but it causes the OS to crash after 30 secs, so I have a little bit of work to do on it!
