0 Members and 1 Guest are viewing this topic. Read 89708 times.
Mariusz, that's a good suggestion. From now on it will be sideways! I agree it will be easier for most to get at it that way.gary
How hard would it be to make an add-on tube buffer that users of the ONE and TWO could use. Like a little external unit to put in the signal path with similar look of ONE's and TWO'2, like a neighboring piece between your source and ONE's,TWO's...that would make theseunits more attractive to enthusiasts, first time users to introduce the whole tube rolling, molding your sound idea. Just a thought
Guys..different size tubes have different sound correct? I have a "cheap and cheerful" GF Tube buffer in transit that uses 6J1's and my GF DAC uses 6N3 5670's so I should get a different tube sound with the buffer correct??
Anybody else here using their Sensation with the tube buffer yet?
The 5670/6N3/2C51/396A have different pinouts than the 12AX7 or 6DJ8 families. They are not compatible.
I received some more tubes in finally, will be testing those next week. Anybody else here using their Sensation with the tube buffer yet? Mariusz, how is your amp sounding? Has it fully broken in?
Stock JJ tube is OK but a bit sterile and harsh to my ear.Mullard which I got this weekend from our mutual friend is somewhat blunt but in a good way.
What speakers are you running? What kind of tweeters? You might want to try a Raytheon or RCA if the JJ is too bright on your system, They are on the warm side, but not as much as the Mullard. I just got in a new tube in this week, and it is blowing me away. Best vocals I have heard yet. I need to do more tests.
What tube are you trying in the buffer?
