What is your latest acquisition?
0 Members and 2 Guests are viewing this topic. Read 416028 times.
1oldguy
Re: What is your latest acquisition?
« Reply #760 on: 1 Sep 2011, 08:18 pm »
Kimber Select KS 1126 1 meter balanced.
RLL1
« Reply #761 on: 1 Sep 2011, 09:20 pm »
Nice!! Are you going to run them from the preamp to the amps?
sweetspot
« Reply #762 on: 1 Sep 2011, 11:20 pm »
                 So, you will not be running your amps close to your speakers?
SoundGame
« Reply #763 on: 2 Sep 2011, 12:40 am »
Nice Kimber Kables - very sharp looking but at roughly $1200 / meter they are too rich for me.  Hope they sound as good as they look.
How did you decide on them without yet hearing your system and deciding what you needed a little more of or a little less?  Room factors are a key part of why you might consider tailoring sound with kables - just nips and tucks, mind you, so how do you make up your mind when there are so many cable out there?  Just curious. :scratch:
sweetspot
« Reply #764 on: 2 Sep 2011, 01:00 am »
That case doesn't look cheap !
1oldguy
« Reply #765 on: 2 Sep 2011, 01:49 am »
I heard the Silver Streak .....It the same deal just more of a good thing.
Will use it to hook up my BCD-1
JfTM
« Reply #766 on: 2 Sep 2011, 01:45 pm »
DIY XLR interconnects between my BP25 and 4B ST.
Made with VanDamme quad and Neutrik gold plated connectors.
Run silent, run deep :)
gaderson
« Reply #767 on: 10 Sep 2011, 12:26 am »
Ventured up to 'The City' (i.e. San Francisco) to a Mastering Studio to pick up a Manley Skipjack from Craigslist:
I also got a quick listen on the mastering suite seen it the intro page of his site (a pair of Focal Grande Utopia EMs powered by VTL Siegfrieds :P). Just a quick listen as my meter was only for 20 minutes.
Great price and I can finally do some AB listening tests.
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #768 on: 16 Sep 2011, 12:31 pm »
(Image is clickable)
...to replace the lesser...
James, if you are still looking for the ultimate tweeter for a normal price, this is it.
Amazing clarity and brilliance.
I first changed one loudspeaker, then listened for a while to a monofied recording, the difference was stunning... A curtain was removed. I actually tested this by hanging a curtain over the new tweeter, and then it sounded the same...
SoundGame
« Reply #769 on: 16 Sep 2011, 01:02 pm »
Hi Anonamemouse,
Nice closeup shots of that install; however, I noticed you are not using any kind of seal, gasket between your drivers and your cabinet.  Would it not help to improve some micro vibrations between the driver and cabinet if you used some type of thin silicon, rubber seal / gasket?  Just curious, since it appears you've gone to such great effort to build those speakers.
Anonamemouse
« Reply #770 on: 16 Sep 2011, 01:18 pm »
Hi Anonamemouse,
There actually is something between the unit and the cabinet, a thin transparent layer of some sort of silicon like stuff. It actually was not neccessary to put it in, since the seal between the units and the cabinet is basically air tight anyway.
As for vibrations, the cabinet is made of oak, I have tested for vibrations using a sheet of tin foil on top of the cabinets at a VERY unpleasant volume, and not a single ringing from the foil whatsoever. These babies weigh over 180 pounds each...
SoundGame
« Reply #771 on: 16 Sep 2011, 01:29 pm »
Well, if you have used a silicon that should help - if you don't detect / hear any vibrations then that's good.
An interesting choice to go with solid wood over MDF/HDF.  My understanding is that they don't use solid wood for building speakers since it is difficult to impossible to match the resonances / natural sound characteristics between two pieces of wood - given the natural variations in density etc.  An analogy would be that two violins, no matter how identically built, will never sound exactly the same.  So it would follow that two speakers made of natural wood would also be virtually impossible to match.
How were you able to overcome the difference in the sound characteristics of the enclosures.
Anonamemouse
« Reply #772 on: 16 Sep 2011, 03:14 pm »
It's something silicon like. I don't remember the name of it. I actually put it in after about 6 months, and did not notice or measure any difference.
It's not just wood, it is 1.2 inch / 3 cm solid oak, one of the "deadest" woods. The inside is lined with 0.1 inch / 2.5 mm lead, open cavities are filled with silver sand which was vibrated to an almost solid mass. Any resonance is killed effectively... :)
I have measured both intensively, in a measuring chamber. There is a difference between them, but this difference is even smaller than the difference present in factory produced loudspeakers.
Laundrew
« Reply #773 on: 17 Sep 2011, 12:47 am »
My "new-to-me" 1942 Monarch 10EE Sensitive Precision Toolroom Lathe was delivered today. A few tweaks are in order such as replacing the DC drive system with a 3 phase motor - VFD control and DRO. Who knows, perhaps a new coat of paint may be in order next year to celebrate "her" 70th birthday.
 :D
Be well...
SoundGame
« Reply #774 on: 17 Sep 2011, 02:06 am »
 :D
Hey Laundrew - pardon my ignorance - but what do you do with this equipment, actually put it to use or appreciate as art or something in-between?  Where do you keep it all?
Laundrew
« Reply #775 on: 17 Sep 2011, 01:17 pm »
Greetings SoundGame  :D
Before we moved, I had "smaller" machine equipment that I could house in our unfinished basement. You can actually see my first lathe to the right of my Monarch.
Our basement in our current home is finished and with the Monarch lathe weighing in at at well over one ton dictates that I construct a small room in the garage for the interim period. We are looking at moving in a few years and then I can have a dedicated studio.
I enjoy robotics and Steampunk Art and have been absent from these pursuits for much too long. I also consider myself most fortunate to acquire equipment such as my Monarch for both functionality and aesthetics. It is extremely humbling when you think of what the history of my Monarch is as it was "born" when the world was at war.
Somehow I find myself "unworthy."
My robotic artist, Phineus with Lady Laundrew and my selves best friend; Hector  :D
An example of Steampunk Art (not created by me).
Be well...
spinner
« Reply #776 on: 17 Sep 2011, 05:44 pm »
Beautiful speakers but what brand are they? :scratch: What make is the tweeter?
1oldguy
« Reply #777 on: 20 Sep 2011, 09:52 pm »
I've waited 6 years for this......Finally
Season 2 of the greatest show period.
Sept 27th it will be mine.
http://tvshowsondvd.com/n/15512
headshrinker2
« Reply #778 on: 21 Sep 2011, 01:20 am »
Outstanding!
Laundrew
« Reply #779 on: 21 Sep 2011, 11:49 am »
