What is your latest acquisition?
Construct
Re: What is your latest acquisition?
« Reply #120 on: 19 Jul 2010, 11:19 am »
:o Very nice! So did you have to anchor your pictures to the wall?  :rock:
I will include such details in my forthcoming review in a week or so.  I have to listen bit by bit as time allows.  I don't want to rush to conclusions.
vegasdave
« Reply #121 on: 20 Jul 2010, 10:56 pm »
Sounds good.
VOLKS
« Reply #122 on: 20 Jul 2010, 11:50 pm »
VTI AMP STAND..........My CS15 TORUS is sitting on it :thumb:
drummermitchell
« Reply #123 on: 21 Jul 2010, 12:01 am »
Nice,clean setup there Volks :thumb:.
I just aquired another F-113 sub(4).two for music and two for movies.I think I were done with the bottomend now :thumb:.
BrysTony
« Reply #124 on: 21 Jul 2010, 12:06 am »
That is a nice setup Volks.  I was wondering which iPod dock that is and how do you like it?
Tony
VOLKS
« Reply #125 on: 21 Jul 2010, 12:17 am »
haha i bet....awsome subs the F-113s
vegasdave
« Reply #126 on: 21 Jul 2010, 12:17 am »
Yeah, really cool setup, Volks.
VOLKS
« Reply #127 on: 21 Jul 2010, 12:18 am »
Tony
Thanks Tony..............its the KRELL K.I.D(Krell Interface Dock)
http://www.krellonline.com/kid.html
NOT your average IPOD Dock :)
BrysTony
« Reply #128 on: 21 Jul 2010, 04:02 am »
NICE!!
Tony
vegasdave
« Reply #129 on: 21 Jul 2010, 07:24 pm »
What advantage does that have over plugging in the Ipod directly into the pre-amp?
VOLKS
« Reply #130 on: 21 Jul 2010, 10:21 pm »
 Krell core engineering technologies populate the circuitry, including discrete, differential, Class A analog circuitry. Optically isolated from the digital circuitry, the KID topology passes signal through a custom 256-step volume control and ends in balanced and single-ended audio outputs.
The KID Dock defines what is sonically possible when using an iPod as a music source. Coupling the convenience of iPod with Krell electronics elevates iPod listening to a level audiophiles will find unexpectedly thrilling.
Bottom line..............it sounds amazing thru the KID dock compared to just plugging it into the preamp on its own.The harshness/shrill of the masive digital compressed Ipod Apple lossless is all but gone and the Ipod  sounds like a CD,but with the convience of over 45,000 songs at the touch of a button.Of course.......all this hooked up to a Bryston/Kef Reference combo helps as well :thumb:
Ryanz
« Reply #131 on: 22 Jul 2010, 12:38 am »
Very Nice! :thumb: Although, it's a shame that we have to spend so much money just to make an iPod sound good.
vegasdave
« Reply #132 on: 22 Jul 2010, 12:41 am »
I see. Well, that sounds alright.
Construct
« Reply #133 on: 22 Jul 2010, 01:05 am »
I have yet to encounter anyone that considers an ipod playing apple lossless "Shrill and harsh"  that is simply an extreme exaggeration to justify a products existence.
VOLKS
« Reply #134 on: 22 Jul 2010, 01:27 am »
are you kidding?Plug an ipod into a bryston system or any other decent Hi Fi using the ipod output with a typical red-white RCA/Patch cord directly into a preamp and listen to the Ipod...............its pure S**T..........its digital compression at its worst.
Construct
« Reply #135 on: 22 Jul 2010, 01:29 am »
Sounds like you are describing what I hear from some Krell products, and the way some have described bryston.    I don't use patch cords myself, USB works great.  I have heard ipod direct-input demos now for a few years at several hi-fi dealers. YMMV.
srb
« Reply #136 on: 22 Jul 2010, 01:34 am »
How do you get over 45,000 songs in Apple Lossless format on an iPod?  They won't fit.
Because the iPod does not have a great internal DAC, using the analog line out on an iPod isn't nearly as good as taking the digital out into a good external DAC, but there is certainly no "digital compression" being performed.
Construct
« Reply #137 on: 22 Jul 2010, 01:43 am »
The harsh "noise"  is more likely the ipod audio amp to the headset jack, not digital artifacts.  Incidentally, at a 50% compression rate (approx.)  45,000 ALAC format songs would take an ipod with roughly a 1462500  megabyte storage capacity. ( I usually get about 350mb per 60 min cd)
srb
« Reply #138 on: 22 Jul 2010, 01:49 am »
I think the "noise"  is more likely the audio amp to the headset jack, not digital artifacts.
I can't imagine anyone who has a decent audio system or reads this forum would use the headphone output of an iPod to plug into their stereo system!  A $30 iPod dock or a $10 dock to audio connector cable would instead get you a true line level output as compared to the amplified headphone output.
Construct
« Reply #139 on: 22 Jul 2010, 01:51 am »
Yep...agreed 100%.  Trying to make the headphone jack sound good on a hi-fi is fruitless.
