e
0 Members and 1 Guest are viewing this topic. Read 3267 times.
emilraaf
e
« on: 10 Jun 2010, 06:45 pm »
t
« Last Edit: 14 Jan 2011, 08:54 pm by emilraaf »
es347
  • ..I've got my eye on you...which one you say?
Re: lack of treble in my vr4 gen 3
« Reply #1 on: 10 Jun 2010, 07:05 pm »
Hi Emil,
What type of speakers that your friends own are you comparing your VSAs to?
emilraaf
« Reply #2 on: 10 Jun 2010, 07:11 pm »
My brother has ML Prodigy and my other hifipal has got a pair of vr 4 gen 1. Its not that my speakers sound bad but i miss some brightness. ive tried to move them in every direction. Ive tried with different speakercables. Almost anything i think..
McTwins
« Reply #3 on: 10 Jun 2010, 08:48 pm »
Hi
I own the same speakers as yours.
What kind of gear are you using and are you running single or bi-amp?
How is your first reflection treated?
Have you tried with a different amplifier, maybe somthing wrong with it.
emilraaf
« Reply #4 on: 11 Jun 2010, 06:15 am »
I have nuforce 9 se v2 and i also tried with a Mark Levinsson 334. I have a krell kps 20i/L that i exchanged with a AR cd3 and Krell KRC 2 but the problem remains. Nordost balanced cables and for speakercables i have harmonic tech 9
JackD201
« Reply #5 on: 11 Jun 2010, 01:23 pm »
Do you have heavy curtains and lots of soft furnishings?
emilraaf
« Reply #6 on: 11 Jun 2010, 11:17 pm »
No..
 not at all.. I have soft curtains.  I will insert an image of my livingroom so you can see what i mean
The pic is old but the placement is the same
emilraaf
« Reply #7 on: 11 Jun 2010, 11:21 pm »
now the speakers are in the same place but the electronics are placed to the left of the right speaker and i have added some big flowers behind the speakers.. its called compromise
Yea i now my english is´nt what it used to be but at least im trying:)
McTwins
« Reply #8 on: 12 Jun 2010, 05:59 am »
Hi
Great room but this is not the best placement for the speakers to be in. You must have some different stereo image in the left and right channel due to that the left has opening in the back compared to the right and that the bass must be wrong also. Meaning, there is no symetry between left and right speakers. You should try to to place the speakers in different position.
"Det är inget fel på din engelska" :D
wimck
« Reply #9 on: 12 Jun 2010, 06:48 am »
Hey!  my VR4 gen3 did look totally different  :D
emilraaf
« Reply #10 on: 12 Jun 2010, 09:13 am »
hehe I know but that was the only pic i had.
Even if i had curtains behind the speakers it woulnt affect the treble or im i wrong?
McTwins
« Reply #11 on: 12 Jun 2010, 09:52 am »
Hi
Send some more pictures, I would like to see how your listening position looks like. About the curtains, it dosen't matter or would help with your treble problem.
I do belive that you have problems with your bass response and that causes the treble problem. You have to do some room measurements to actually see what the problem is. I can do it for you if it is not far from my home.
Where do you live in Sweden?
emilraaf
« Reply #12 on: 12 Jun 2010, 01:33 pm »
I live in Uppsala. How far is that from you?
McTwins
« Reply #13 on: 12 Jun 2010, 04:21 pm »
Hi
Very far, as south as one possibly could go. Well, that's pitty, but keep tweaking.
McTwins
« Reply #14 on: 18 Jun 2010, 12:27 pm »
Hi
Have you found the problem with your treble problem?
emilraaf
« Reply #15 on: 29 Sep 2010, 04:49 pm »
Yes.
I moved them closer to the backwalls.. strange but it works. I think they become more stable that way. First i had them 140cm from the wall and now 70!
