0 Members and 3 Guests are viewing this topic. Read 260147 times.
Thanks to all of you.@AVnerdguy and djmckaytx:Which de-embedder have you been using with your Oppo 93/95? It seems that not every player/de-embedder combination is working.
I assume you rip SACDs with a Play Station? From what I've read here, it seems that is the only way.
I have been 100% dedicated to the Mr Wicked project (I am a beta tester) of doing true SACD DSDIFF and ISO ripping. It uses the PS3 as per my other threads about it. I have completed version 1.2 of a word doc or pdf that walks you through "SACD ripping For Dummies". i'll send it to anyone who needs it. PM me your email addy.
I use the Port-ta/Monoprice de-embedder with a BDP-83 and don't need a handshake. I've also used the de-embedder with an old Oppo DV980H in the secondary basement system and do not need a handshake. I've not been able to get the BDP-93 to work under the same circumstances, although I have not exhausted every combination. I have the BDP-93 in the secondary basement system and at some point I'll experiment more. It's not a big deal in the basement system as I have the BDP-93 going into an Onkyo 1008 so if it needs a handshake I can always try the second HDMI out.
Hello Phil, I would appreciate some help from you regarding my questions.... Can you help me please? Expecially about choosing the best connections between OPPO, Monoprice and the DAC.Thanks again
I couldn't get it to work with the BDP-95 either.
When 24/192 files/disks are attempted, the 840C doesn't see a valid signal and I get mostly silence with occasional "bits" trying to break through. However, these occasional sounds tell me that the 840C is receiving some sort of signal.The only thing I may be missing are higher SACD rates (I'm new to hi-res, so I don't even know what the typical recording rates might be) or 24/192 blu-ray material. I don't have any verifiable blu-ray material to test at this point however.I would like to solve the playing of higher-rate SACD's or 24/192 material via the 5777.
