0 Members and 3 Guests are viewing this topic. Read 260140 times.
No problem, sorry for the title.. Back when this started it was the ONLY option. SACD ripping was not invented yet (thanks Mr Wicked). I'm now doing nothing but ripping.
I'm in the midst of developing a primer, with screen shots. Stay tuned.
2. Has anyone compared the quality of the Oppo DSD-PCM conversion with the Foobar SACD plugin conversion (by playing a PS3 SACD rip on the PC and burned to DVD-R on the Oppo)? Both do DSD --> 24/88, so it would be interesting to know if there are differences.Thanks.
Interesting. I'm wondering if there is a consensus on how good the actual DSD to PCM conversion is in many of the players that are available as SACD transports. And, if the conversion process itself is the biggest obstacle in getting really good sound out of the SACD format. I saw a post made by HumanMedia (on AA) that said, "Keep in mind that the on-the-fly PCM conversion of most players is VERY rough and flawed. For example at least one Sony player adds noise to the PCM signal (even in areas where there is digital silence) and the Oppo players add excessive gain and the PCM signal clips."I would like to learn more about that if I can.FWIW, I recently purchased one of the HDMI de-embedders and a few SACDs. I am using an Oppo BDP-83 for the transport and my DAC will lock onto the 88.2kHz coming out of the de-embedder. (It does truncate to 18 bits however.) It sounds pretty good to me so far, but I need to buy some more SACDs to get a feeling for whether or not it is a big improvement over a well done CD. It is certainly fun though! (Still learning . . . )
1. Has anyone successfully used the procedure with the Oppo 93? Which de-embedder was used?
Super interesting circle, this is just what I was looking for.My TV only accepts up to 48 kHz sample rate as input over HDMI. It does accept 24 bits though. As far as I understand, this means that I will get the benefit of 24 bits, but not get any higher sample rate (88/176/192) by using the Atlona or the Porta/Monoprice boxes, because the TV will do the HDMI handshake and limit the sample rate to 48 kHz.I checked the newest TV models from Sony and Samsung, and they have exactly the same spec. So this problem would likely apply to most people trying to use such a solution with a TV. I don't have a HT receiver, only a 2 channel stereo where I'd like to get high def sound from SACD and Bluray played on PS3 into my Hegel HD10 DAC.Is it worth it to get the $40 Monoprice box in order to increase bit rate from 16 to 24? How important is the increased sample rate versus the increased bit rate in HD sound?What would be the best solutions out there to get 192 kHz also, or at least 88 kHz? I guess I could get the Atlona 577 or the Monoprice + Grefen detective, and then go to a local shop to capture the EDID of a receiver which accepts 192/24. I think this could work with SACD, but with Bluray I need the TV to be connected through HDMI to get the picture, and then I fear the TV would interfere in the handshake and still limit the sample rate to 48 kHz.Any help would be greatly appreciated!
I'm pushing this thread to repeat the question if someone has done this with an Oppo 93 or 95. Some posts above indicated that there might be a difference between the Oppo 83 and the 93 in that respect.I just discovered that the Oppo 93 does only output 24/48 maximum through S/PDIF when playing Blu-ray discs (while there is no such limitation for DVD-A). I have a couple of Naxos Blu-ray Audio discs with 24/96 sound that I would like to hear in full resolution through my DAC (Electrocompaniet ECD-1). So this would be another reason to try the de-embedder route.Thanks
I've tried it with the 93 but was unsuccessful. I followed all of the procedures from the posts to no avail. Then I started experimenting. After many hours I had to quit. I tried briefly again when the frustration level died down but no satisfactory results. That was a few months ago. I recently picked up some new gear (BDP-1/BDA-1, AVA 600R, and upped my DSL to 12Mbps) and I will be back in the rack installing equipment so I started researching again. I have 2 weeks off for the holidays so I'll have plenty of time to experiment. I will have done more research by then and hopefully I will get favorable results. If I get this resolevd I'll post.
Thanks to all of you.@AVnerdguy and djmckaytx:Which de-embedder have you been using with your Oppo 93/95? It seems that not every player/de-embedder combination is working.
I have successfully used a de-embedder with the 83SE and now with a 95. Now that I can rip my DVD-As and SACDs to hi-rez, using the de-embedder with the physical disc seems like a bit of a downgrade to me. I use the USB ports on my 95 to play 24 bit (88.2/176.4) FLAC files directly into my WFS DAC-2. Greatness...all my DVD-As have been ripped for awhile now -- and I cannot rip my SACD discs quick enough.If you're contemplating an 83SE vs. a 95, grab the 95. I happen to have an 83SE that I'll sell if anyone would rather have it. Hope this helps.
