Fired up my recently acquired Atlona hd577 for first time. Mixed experience. On DVD-A from Cambridge Audio 650bd (same mediatek chip as Oppo) went to 24/192 via hdmi & spdif co-ax, but I definitely prefer dvd-a with ca 650 as transport & spdif direct into cyrus dacx. Tighter, more extended into bottom end, at least. We'll see if bedding in changes this over time.Some issues - 1. then played a blue ray disc & screen had deep green all over it. Went through all menus & couldn't see anything amiss 2. changed the hdmi cable over & then couldn't get hdmi audio out of 48khz, despite shutting down & re-setting edid. 3. then went to hdmi input 2 & reset everything again: eureka! 24/192 etc back, plus a real non-green hd image on blu-ray.So what was that all about? I sense instability here! I haven't gone back to input 1 yet. But, sacd is next - I need to get one, or more ...
I think I eventually figured out it was the order of power on - try bluray player on first, then atlona on second. Good luck with its temperamental nature!
Should I replace the Maverick with an Emotive XDA-1 to get the full, rich buttery hi-fi goodness?
There is always the promise of a better DAC for the buck around the corner that is often more marketing hype than substance, but I would at least wait for the feedback on the soon to be shipped Schiit Bifrost DAC.
Thanks for that info -- the Bifrost looks interesting. You make very good points about the Emotiva, and those are things I'm not interested in.Just to clarify -- if I can get 192 kHz out of the Oppo, but my current DAC only accepts 96 kHz, it'll be an improvement over the RCA audio output, right? But if I get a 192-capable DAC I'll hear the full potential of the audio output?I wonder what the Maverick would do if I fed it 192 kHz?
Having read through this long topic with great interest, may I ask for a summary of the state of the Sony art? That is to say, where do we now stand regarding the extraction of PCM from an SACD played on a current Sony Blu-ray machine, accompanied by an Atlona HD577 de-embedder?As I understand it, Oppo OK but only 88.2kHz. Sony, theoretically 172kHz but ???. Any other options? As I see it, with the gathering momentum and increasing availability of hi-res files, there are distinctly sensible limits to the level of investment for the "ripping SACD" project and time, for this format, seems to be rapidly running out.
Welcome to the forum. If you read the last few pages you only get 16 bit from the Sony but 24 bit from Oppo.
I use a BDP-83 in the main system with the Port-ta/Monoprice de-embedder and it requires no handshake
...I have to re-visit the Oppo BDP-93 again at some point...I could not get it to output sound via the de-embedder and I probably have to try alternative settings.
Would appreciate further analysis of this aspect. I'm surprised that there appears to be any functional difference between two Oppo units of such similar vintage.
HI,Bluecoast offers SACD downloads in Dsdiff format. Any thought on how to play these files through my BDA directly or is that not possible? http://bluecoastrecords.com/dsd-info Would like to skip the Disc-burning now that I have the BDP1...Mariussorry if this has been discussed already or elsewhere, please point me to that then...I'll ask on the Bryston forum also.
Marius,This is an HDMi de-embedder thread. I'd be happy to discuss on another thread. (BDP won't play native DIFF files, must be converted to PCM as I do all my SACD rips....see SACD rip with PS3 thread)
