0 Members and 5 Guests are viewing this topic. Read 260220 times.
Phil A: "As noted in recent pages, I have not been able to get 24/176.4 with a Sony Blu-Ray player. The DAC showed it receiving the signal but I got no sound."Phil, I've had this same issue, when I got a Sony BDP-S370 for sacd conversion to 176.4, with an Atlona 577. My CA650BD (Oppo chipset) is fine with 88.2 conversion & sound out of dac, but with the Sony the dac shows the 176 conversion - but no actual sound signal. Did you sort your problem with this?
I think I have this straight, but perhaps someone with more experience could confirm it?If I buy the Monoprice box to take the signal from my Oppo 83, will I still need to connect the HDMI output of the Monoprice to something (will a HDTV only work? will a Geffen HDMI Detective only work too?) Is the highest resolution for SACD's this way 24/88.2? Will the Monoprice pass 24/192 from DVD-A's and/or Blurays with a 24/192 recording?Thank you!
Thanks, but do I ever need to hook the Monoprice up to an HDMI device for a "handshake"?
Thanks Phil, hope you sort it eventually. Meanwhile, I'm still chipping away at different ways through this no sound pass-through of displayed 176.4 from Sony into Atlona 577. I just don't fundamentally 'get' the concept of having the dac clearly receive the 176, but has no signal to give to the pre. Explanations?
FWIW, I establish the initial handshake with my OPPO player and then use the de-embedder switch to change over to the Sony (I use the Sony for SACD and the OPPO for everything else). About as often as not, when I try to use the Sony first, I can't get a feed until I get the OPPO to handshake. Seems odd and I have no idea why this pattern has developed, but, if I start with the OPPO, then switch to the Sony, I have no problems getting 176 sound out of SACD's. Good luck. Cordially,
