0 Members and 2 Guests are viewing this topic. Read 260283 times.
Why would the 24/192 dvd-a sound superior via hdmi, as compared to spdif coax? Less jitter? Haven't picked up a difference myself.
Ted - when you say you'd still go coax from the player for DVD-A 2 channel, I'm wondering how that relates to my earlier questions and your responses on Feb 18 and 19. Based on that I was planning on buying an Atlona HD577 to go between my Oppo and Modwright Transporter used as a DAC so I could listen to the higher resolution SACD layer of my SACDs. Currently I hear the CD layer streamed via an ethernet cable from my Mac. I'm also planning on buying some DVD-As. Does what you said above mean I could just go straight from the coax output of the Oppo directly to the Transporter and get the same result?
I see, thanks for that very clear explanation that even an old analog novice to digital audio and HiRez in particular can understand. Since stumbling into this last week I’m excited about HiRez. I’ve been reading a lot in your circle but still have questions. Not sure if this circle is the place to ask, but here’s one.I want to start downloading from HDTracks and other sources. So far all the titles I’ve looked at are available in FLAC only. Since I use a Mac and iTunes my understanding is I can’t use FLAC, but I was thinking of getting Pure Music or something similar which can read FLAC natively I guess is the term. Then I read Wayne1’s response in this short discussion and I’m not sure how it effects what I’m trying to do:http://www.audiocircle.com/index.php?topic=91091.0
Okay will do, didn't know about converting FLAC to AIFF.Don't think Pure Music will do anything in my situation if I understand Wayne1's comment in the link above. He says "To use the Logitech Touch (Transporter in my case), you must use SqueezeBox Server. That is your music control program. iTunes has absolutely nothing to do with the Transporter. Exit the program. There is no need for it. Pure Music will not do anything with the Touch. The Touch, along with SqueezeBox Server, will stream native 24/96 without you having to do anything."
