0 Members and 2 Guests are viewing this topic. Read 260279 times.
Thanks, Ted, I didn't know that about the paucity of 24/192 Blu-Rays. The Monoprice thing I discovered purely by accident. It comes with a remote that has two buttons, one for 5.1 and the other for 2 channel. When I had the Monoprice set to 2 channel, all I could get out of SACD's was 44.1, regardless of the Sony's settings. When I changed the Monoprice via the remote (there's no button for that on the unit itself, IIRC), I was rewarded with 24/176 for SACD playback (and the sound difference between the two is immediately noticeable). I'll post when I resolve my issue.If anyone else reading this thread has an answer about the Sony's settings to the question I posted earlier, I'd appreciate reading your input. Thanks. Cordially,
I have a Sony 5400 presently at Modwright for the full upgrade.I also have a Mac Mini/Minimax DAC system.I saw this thread and ordered a Atlona HD570 immediately.SACD on the Modwright vs. the Minimax via the Atlona box should be interesting.
Paul,The 5400 is not a candidate for this. The 5400 does not do DSD-to-hirez PCM conversion. The HDMi outputs are for DSD (stereo, multichannel) only, unless it's a cd. If the EDID handshake were to work and force PCM (some reports it does) then reports are that it downrez's all the way to 44k.
I was thinking, as I was about hit "Place Order", perhaps I should read the whole thread. It turns out I do have an Oppo 83 (non-SE) as well. It is the family DVD spinner and nothing more. So, I can still do the "experiment".
Thanks for answering these questions from a board newbie. I'm getting ready to setup using an (unopened) Oppo BDP-83SE and an Atlona 577. My questions are:(1) Is anyone using a Logitech Transporter as their DAC in this scenario and if so, what bit rates are you connecting at?(2) Has anyone used a Sony BDP-S770 as the SACD transport in this scenario? What bit rates would the Atlona be able to de-embed from SACD?The reason I ask is that just about everything I own and care about on DVD-Audio I've already ripped an archive copy of and can play through another method. If I could get 24/176 from my SACD collection (which would be my goal) through the Sony S770's HDMI, I would have no real reason to open the Oppo box...and would probably just sell it outright.Thanks again. Great board and thread here.
Anyway:1) The Transporter will only do up to 24/96 via it's digital inputs (or streaming for that matter)2) yes, the Sony 7750 (as well as the 370 and 570) all do 24/176k assuming you set the SACD as PCM and not DSD (set up menu). The only thing the Oppo will do for you is multichannel DVD-Audio (since you've ripped, like me, all your good 2 channel DVD-Audio).
yes, the Sony 770 (as well as the 370 and 570) all do 24/176k assuming you set the SACD as PCM and not DSD (set up menu).
I still don't get how 176khz is achieved... perhaps you could help me understand:1) With the monoprice HDMI switch in 5.1 the 24bit/176khz output is in 2 channel stereo?2) Does that mean it is reading the 5.1 track from the disc and down-mixing to 2 channel?3) Are you alluding to that this is a bug of the monoprice switch that it can output highRes content via the digital output while others are normally disabled or mute? Thanks,
3) For hi-rez SACD and DVD-A (except that the Oppo does it on DVD-A) due to copy protection output for hi-rez digitally for SACD was with HDMI (a one way digital connection) and not until HDMI version 1.2 and later. This allows one to pass hi-rez via a normal digital output.PS - welcome to the forum
Phil A, thank you for the informative reply. It's much appreciated.If I understand it correct, the monorprice HDMI switch basically just outputs hi-rez via SPDIF. I guess what I am trying to confirm is the maximun resolution of it - is it 88.2 or 176? This could very much be the perfect solution for me to finally enjoy my SACD collections in it's hi-rez format closes to it's original.Thanks,
