0 Members and 1 Guest are viewing this topic. Read 3343 times.
As a general principle, and of course I should say YMMV, an upgrade needs to address component choices first, operating point second, and maybe wire last of all. I tend to tune everything by ear; most of my time goes into component choice and operating point once the topology/schematic has been figured out. I feel that the design is only mature when as many components as possible have been removed from the circuit. I was disappointed with the GK1 because there are so many caps in the front end; but Darl and I tried very hard to remove them, and every excision resulted in a one-legged presentation, so we HAD to put 'em back in! I am absolutely convinced that the best sonics come with elegant minimalism; generally I have noticed that this applies across all technologies. Complexity is easy, and often indicates incomplete or even flawed R&D. Simplicity, production repeatability, careful component selection results in higher reliability and lower cost and is the essence of good design.
... I tend to tune everything by ear ...
Harmonic Distortion: Total Harmonic Distortion at 1 kHz into 8 ohm resistive load using HP339: 0.2% at 0.1W; 0.08% at 1W; 0.007% at 10W and same to clippingAt 10kHz and 1W into 8R resistive: 0.042%; at 20kHz and 1W: 0.045%.Not exceeding 67dB below (0.045%) at any frequency to 20KHz for 10W to 95W into 8R. Distortion profile is second and third harmonic, both 'musical', with all other distortion components, including intermodulation, immeasureable and below the noise floor.
At the time, Robert assured me that the distortion was all H2 and H3, and in fact that had been my precise aim during the design phase.
4R7 emitter degeneration on the diff amp- else bog (Nivarna) standard
