Bryston BDP-1 Sneak Peak for Audiocircle
0 Members and 1 Guest are viewing this topic. Read 190453 times.
srb
Re: Bryston BDP-1 Sneak Peak for Audiocircle
« Reply #480 on: 27 Nov 2010, 09:01 am »
Cover to cover? Man, that must have taken some time to compile!
650+ Issues / 100,000+ Pages / $300
vegasdave
« Reply #481 on: 27 Nov 2010, 09:19 am »
 :o
nikon
« Reply #482 on: 28 Nov 2010, 12:18 pm »
Hi James
Is the USB drive shipped with the first BDP-1's similar to the following
http://www.customflashdrives.net/flash-drives/organic/pedaltothemetal/
Will Bryston be offering the USB drive under Bryston stuff
whanafi
« Reply #483 on: 28 Nov 2010, 02:37 pm »
That's what they invented interns for.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #484 on: 28 Nov 2010, 02:45 pm »
Hi James
Hi
Do not think so as we only got 200 units and intended to give them free for the first bunch of BDPs sold. At the rate the BPDs are selling we will be out in a short while.
James
alexone
« Reply #485 on: 30 Nov 2010, 10:14 am »
James,
is there a Bryston-App ready for download in order to use ut with iphone, ipod, ipad?
al.
nyc_paramedic
« Reply #486 on: 30 Nov 2010, 02:08 pm »
James,
You can use MPod: http://www.katoemba.net/makesnosenseatall/mpod/
« Reply #487 on: 30 Nov 2010, 04:06 pm »
James,
al.
Hi Alex,
The Bryston MAX and MINI are built into the software of the BDP-1 so most products that have a webbrowser can (see) interface with the built in MAX or MINI. Because it use HTML and a webbrowser it is slightly slower than an APP which is specifically written for a specfic device.
So MPOD is an example of an APP that works with iTouch, iPhone and iPad and is very quick and works well with the BDP-1 using the Linux operating system in the BDP-1.
Minion is another APP designed to work inside the Firefox browser with the BDP-1 and it works really well on a desktop computer screen.
So the idea is to allow as many different handheld and desktop/Laptop type products to interface with the BDP-1.
Hope this helps.
james
alexone
« Reply #488 on: 30 Nov 2010, 04:09 pm »
ok, thanx Paramedic & James.
al.
nyc_paramedic
« Reply #489 on: 30 Nov 2010, 04:58 pm »
I'm working on some experimental stuff with a Kindle. Super long battery life; no annoying back light when listening in a dim listening room; excellent screen contrast in low light.
« Reply #490 on: 30 Nov 2010, 05:08 pm »
Looks great :thumb: -- keep up the good work!
james
TomS
« Reply #491 on: 3 Dec 2010, 03:14 pm »
James,
Any reason why the BDP-1 could not be set up to output 24/192 USB for those with hi-hiz USB DAC's in addition to AES or S/PDIF?  Linux already supports USB to 24/192 in Voyage MPD 0.16+ so it should be a configuration change only.
I'm using an Alix/Voyage MPD motherboard 16/44khz right now into my Bryston BDA-1 USB input, just learning about MPD and various MPD clients, and it seems to work just fine.
Tom
« Reply #492 on: 4 Dec 2010, 01:52 am »
Hi Tom,
I will ask the software guy - I guess anything is do-able but it would also mean a backboard and output circuit board change as well I assume.
james
TomS
« Reply #493 on: 4 Dec 2010, 12:51 pm »
Hi Tom,
james
I wouldn't think there would be any hardware change though there may be confusion on whether the USB port is for storage or output to DAC.
« Reply #494 on: 4 Dec 2010, 02:22 pm »
Oh - I see what you mean now - right no warranty if you use the wrong USB port :duh:  and nowhere in the manual do we indicate which is which :D
james
alexone
« Reply #495 on: 19 Dec 2010, 10:21 pm »
James,
any chance to see the BDP-1's manual at the Bryston website soon?
al.
« Reply #496 on: 20 Dec 2010, 12:20 am »
James,
al.
Hi Al,
I can email you the manual - its 4MG
james
alexone
« Reply #497 on: 20 Dec 2010, 04:48 am »
ok. will send you an email.
thanks.
al.
mystabg
« Reply #498 on: 25 Dec 2010, 07:15 pm »
James, I just learned about this new offering while I was researching your dac . So I just finished reading the thread and you said Blue Leds could be a special order Option. Can I get the same option on the dac as well? If not I would settle for the Green so both units would match. Thanks Gary
« Reply #499 on: 25 Dec 2010, 07:18 pm »
I would go with Green - we are having issues sourcing Blue for the DAC?
james
