Bryston BDP-1 Sneak Peak for Audiocircle
0 Members and 1 Guest are viewing this topic. Read 190789 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston BDP-1 Sneak Peak for Audiocircle
« Reply #320 on: 8 Oct 2010, 10:27 pm »
waaaant... WWWAAAANNNTTT!!!!
Would it be possible to trade in my 3 months old BDA-1 for the BDP-1?
No - you need the BDA-1 to sound its best.
james :)
whanafi
« Reply #321 on: 9 Oct 2010, 01:27 am »
What DAC would you use instead?  The BDP-1 is "just" a player.
« Reply #322 on: 9 Oct 2010, 01:35 am »
Sorry whanafi - not sure I understand - what DAC would I use if not the BDA-1?
james
whanafi
« Reply #323 on: 9 Oct 2010, 01:40 am »
james
If he trades in his DAC for the player, how does he get the output of the player to the amp?
« Reply #324 on: 9 Oct 2010, 01:49 am »
Correct - you still need a D-to-A to output to the preamp.
james
gjorgji
« Reply #325 on: 9 Oct 2010, 03:04 am »
Hi James,
With the sizes for today's drives (ex.1TB), how long does it take to scan the drive if its full ( maybe 2.5K flac albums)?
Gjorgji
« Reply #326 on: 9 Oct 2010, 10:39 am »
Hi,
I would say about 10 minutes with 1TB - but once scanned the access to the material is very quick.  But as I have said before I do not think the BDP-1 is for those folks wanting to deal with thousands of songs. It is really geared more to someone wanting to managing and listen to hundreds of songs with the highest quality possible.
Also remember we are talking about USB drives.
james
« Last Edit: 9 Oct 2010, 12:33 pm by James Tanner »
gjorgji
« Reply #327 on: 9 Oct 2010, 04:50 pm »
Fair enough .. is there any particular reason why network storage will not be supported, technical or other? You do support MP3, not exactly the HQ playback  :wink:. I was really looking forward to ditch the SB and attached BDP to BDA. While I fully support not putting wifi anywhere close there, you have already put the ethernet adapter, so may as well use it for something else rather then web server.
« Reply #328 on: 9 Oct 2010, 05:08 pm »
Hi,
MP3 because we have to get the MP3 crowd involved and hopefully motivate them to move up.
We are going to look at a NAS storage option going forward.  That's the great thing about this product and the Linux operating system - lots of options moving forward for us to expand in to.
james
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #329 on: 9 Oct 2010, 09:11 pm »
I would use the DAC in my CD player, the Marantz KI Pearl. It has a consideably newer version of the Cirrus DAC, the Cirrus Logic D/A – CS4398, and (sorry James) it sounds better. I have done a month of hardcore and thorough testing, and the differences are basically just minor nuances, a few  are better in the Bryston, but somewhat more are better in the KI PEarl. If anyone is interested in how I did the comparisan I'll be happy to give more detail, but I am off to bed now, early day tomorrow, doing the A-Ha show here in Amsterdamn.
« Reply #330 on: 9 Oct 2010, 09:26 pm »
The DAC in the BDA-1 is the CS-4398 :scratch:
james
OgOgilby
« Reply #331 on: 10 Oct 2010, 01:17 am »
The Pearl's optical digital input for DAC mode only handles 96kHz max. The BDA-1 goes up to 11 (I mean 192kHz)!
OgOgilby
« Reply #332 on: 10 Oct 2010, 01:25 am »
james
Awesome. Hope that is high up on the priority list James - that would put an end to playing CDs in our house!
KeithA
« Reply #333 on: 10 Oct 2010, 01:29 am »
Sounds like you lost a bet  :P
Keith
alexone
« Reply #334 on: 10 Oct 2010, 12:17 pm »
Hi,
james
James,
you mean that the BDP-1 is not able to play playlists with more than 1000 songs? :scratch:
to have an external hdd of let's say 1tb is just great for this amount of songs...and i believe that most of the people will have more than 1000 songs.
al.
« Last Edit: 11 Oct 2010, 04:53 am by alexone »
« Reply #335 on: 10 Oct 2010, 12:38 pm »
Hi Al
No the BDP-1 can play any number of songs. It just takes longer to load a T-BIT drive over say a 16-G thumb drive which takes a few seconds. Once the USB drive is loaded it stays loaded and you can access the song lists very quickly through whatever interface your using - mPod, iPad, iTouch, iPhone your computer, minion etc. or Bryston web interface.
I realize some people want to play with thousands of files at a time but I think most will use the BDP-1 as I do.
For instance I have a 500G USB hardrive connected to the back of the BDP-1 and it has about 5000 songs on it.  Then I have about 10 Thumbdrives with different material - a Jazz one, a Classical one, a top 25 favorites etc. which I use from night to night depending on my mood.
One of the things I have noticed since I have been using the BDP-1 is I tend to use it more like a large CD player rather than a server.  By that I mean it was kind of neat using all the intefaces on the iPod and Itouch and my computer and such but I found after a while I just wanted to turn out the lights and listen to a few songs.  So I found myself turning off the large and brightly lit interfaces and just using the BR2 remote with the BDP-1 and some thumbdrives and just advancing through my playlists using the Bryston BR2 remote in the dark and sipping my wine- but hey that's me!
james
« Last Edit: 10 Oct 2010, 01:43 pm by James Tanner »
alexone
« Reply #336 on: 10 Oct 2010, 02:15 pm »
ok. it's good to know that the BDP can play any number of songs :D.
al.
Napalm
« Reply #337 on: 11 Oct 2010, 01:00 pm »
[...]One of the things I have noticed since I have been using the BDP-1 is I tend to use it more like a large CD player rather than a server.  By that I mean it was kind of neat using all the intefaces on the iPod and Itouch and my computer and such but I found after a while I just wanted to turn out the lights and listen to a few songs.  [...]
"Told you so". An iPod needs all the glitzy interface to compensate for the crude sound reproduction so the overall entertainment factor is reasonable. But when you got the sound reproduction right, you don't want anything to distract you from listening.
Just remember what people do at symphonic / opera performance. Lights are dimmed/off, and they are all eyes and ears on what's happening on the stage. No laptop/iPod/iPhone clicketing (unless you want to be politely but firmly escorted out of the auditorium).
Nap.
drummermitchell
« Reply #338 on: 11 Oct 2010, 01:25 pm »
I like that idea of having a few of those thumb drives for different styles of music,
or the type of mood your in,excellent.
Can't imagine using a remote to scroll thru a thousand songs or more,let alone a few hundred.
I guess for background music it's fine just put her on random(not for me).
Half a dozen or so thumbdrives,now that I like :thumb:.definately would save some physical time going
thru a few cds for a couple of songs,jeez another early christmas present for the wife :lol: :o.
« Reply #339 on: 11 Oct 2010, 02:41 pm »
Hi Don,
You can still use the front panel 2 line display to navigate through your folders, albums and playlists - its just once your there you can play through the folder or the album using the BR2 remote.  We even have an option on the BDP-1 to turn off the front panrel display if you want - total darkness no less :D.
james
