Bryston BDP-1 Sneak Peak for Audiocircle
skunark
Re: Bryston BDP-1 Sneak Peak for Audiocircle
« Reply #260 on: 3 Aug 2010, 04:45 pm »
I wouldn't call it a mancave product.. the fact that you can use it with an ipod touch/ipad means that pretty much anyone can use it.  Most will consider it more of a jukebox until the resident computer expert can add more songs to it.
Does the ipod touch/ipad app use the file names or the tags to create list of music?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #261 on: 3 Aug 2010, 05:35 pm »
File names.
james
john garnet
« Reply #262 on: 5 Aug 2010, 12:15 pm »
Well this is the answer to my prayers. Finally an audiophile player for files that doesn't require a degree in computing to set up - great sound is all I want! I've got the BDA-1 dac so I'm half way there! James, a couple of questions: USB input to the BDA-1 limits resolution to 16/48. If I have read correctly, USB external hard drive into the BDP-1 has no limitation and can reproduce the full resolution of any file up to 24/192! Is this correct and if so, what is different about the USB between the BDA-1 and the BDP-1?
Also, will this be fully remote controllable including album art and all playlists via an iPhone or iPad? Sorry if you've already covered this.
John
« Reply #263 on: 5 Aug 2010, 03:57 pm »
John
Hi John,
Yes it will play any digital file all the way up to 192/24 bypassing the USB on the BDA-1. Yes you can use an iTouch or Iphone or your computer to manage the play lists.  i use Firefox and Minion for my computer interface and Mpod for my iTouch.
james
BrysTony
« Reply #265 on: 7 Aug 2010, 03:32 pm »
Some USB music:
http://www.cardas.com/content.php?area=music&content_id=9&pagestring=USB+Audio+Cards
james
James,
These look interesting but I don't see any sources on the website.  I checked MusicDirect, a Cardas Dealer, but there is no mention of the USB Audio Cards.
Where can they be purchased?
Tony
« Reply #266 on: 7 Aug 2010, 03:52 pm »
James,
Tony
I believe from Cardas direct - I have some coming to test on my BDP-1
james
BrysTony
« Reply #267 on: 7 Aug 2010, 04:28 pm »
james
I don't see a way to order from them on their website.  I will call Cardas on Monday.  Their support line is open only Mon-Fri.
« Reply #268 on: 7 Aug 2010, 04:51 pm »
I spoke to a fellow named Josh on Friday at Cardas and he seemed to know what's up.
james
sfraser
« Reply #269 on: 7 Aug 2010, 06:04 pm »
james
That's kind of cool, ...for people not comfortable downloading music. Do you know if there is any DRM , or can you copy the files off the thumb drive?
« Reply #270 on: 7 Aug 2010, 07:15 pm »
Hi - not sure on that one?
james
Aramys
« Reply #271 on: 7 Aug 2010, 07:21 pm »
too bad that the BDA-1's (and therefore the BDP-1) milling of the frontplate looks different compared to the "first" production runs that were available :(
i wonder if the older style would be still doable?
al.
100% agreed. :cry: Are those curved left and right front plate sides standard now ?
Aramys
« Reply #272 on: 7 Aug 2010, 08:18 pm »
Aramys
Yes they are the standard look now for consumer product.  The Pro faceplates are different.
james
james
Aramys
« Reply #273 on: 7 Aug 2010, 09:19 pm »
james
Mmm... bad. They've less personality with this design. It accentuates the box aspect. Just my advice of course.
Aramys
SFOX
« Reply #274 on: 7 Aug 2010, 10:19 pm »
james
are any interior and/or rear panel pictures of the BDP-1 available yet - if not when do you anticipate ...
« Reply #275 on: 8 Aug 2010, 01:47 am »
james
I have a unit at home - I will take a shot of the rear for you.
james
1oldguy
« Reply #276 on: 8 Aug 2010, 01:50 am »
James
Look but don't touch. :green:
« Reply #277 on: 8 Aug 2010, 02:01 am »
james
The silk screen is wrong - ethernet and USB should be reversed.
james
Napalm
« Reply #278 on: 8 Aug 2010, 05:07 pm »
^^^^ The tone controls are missing too  :cyclops:
1oldguy
« Reply #279 on: 8 Aug 2010, 05:09 pm »
Yes I noticed that as well. :deadhorse:
