buying used vinyl
0 Members and 1 Guest are viewing this topic. Read 5926 times.
Ericus Rex
Re: buying used vinyl
« Reply #20 on: 9 Jun 2010, 10:54 pm »
In addition to the above suggestions you can go to record shows.  I'm sure Cincinnati gets a few a year.  Make the trip, buy lots of used vinyl and get some great food.  Make a trip out of it.
Here's a site with dates:
http://www.goldminemag.com/news/record-show-calendar-feb-11-2010-2
And another:
http://www.vinyltimes.com/record-shows.htm
Now, some of these sellers are top-dollar.  But I've found others are reasonable to really cheap.  And nearly all will give you quantity discounts.
Best of luck!
drphoto
« Reply #21 on: 11 Jun 2010, 03:35 am »
I picked up 5 used LP's from my local record store yesterday ranging from $4-$6 ea. A couple looked nearly flawless. But even the scuffed ones sounded ok. I'm starting to think that maybe less than pristine condition is not a deal breaker.
Plus, a few ticks and pops doesn't really bother me now. I read a comment somewhere that w/ analogue, the noise is outside the music, but w/ digital the noise (jitter) is within. And that's the big difference. Makes sense to me.
Oh, there's one of those traveling record show things here this Saturday. Hopefully I can pop over there after work and see if there are any deals to be had.
jrtrent
« Reply #22 on: 11 Jun 2010, 12:10 pm »
I've gotten hundreds of used records in the bargain bins at Half Price Books, ranging in price from $0.25 to $1.00, and probably 90% of them have been keepers.  I also like to shop at a hi-fi store that also sells used records.  He typically charges $4.00 per record, but he inspects them and will even clean them on his Nitty Gritty before they go out the door, and he accepts returns for records that prove to have problems (I've never returned an album purchased from that store).  The stores I frequent are an hour to an hour and a half drive away, but I enjoy the trip and combine record shopping with other activities.  I really don't even notice the drive time since it's no more than my daily commute to work was for many years.
orthobiz
« Reply #23 on: 1 Jul 2010, 02:31 am »
Another is recorshowsofamerica.com
Let's you search by map
Paul
