Speakers pairing for Icon HDP + Icon AMP [ Audioengine or PSB?]
chaosteo
Hi all:
How do they each sound with Nuforce and will be a better match? I mostly listen to Ben Harper, Chicago blues, reggae, jazz and Mozart classics.
Or would you suggest something different? Is the NuForce S-2 speaker being delayed?
Thank you all =)
Audioengine P4 Spec:
Type:2-way passive, front ported design
Sensitivity: 88dB (2.83v@1m)
Frequency response:58Hz-22kHz
Nominal Impedance:4-8 Ohms
Crossover Frequency:2.8 kHz
Recommended Amplifier Power:10-125W per channel
Tweeter:3/4" (20mm) silk dome with neodymium magnets
Woofer:4" (101mm) Kevlar cone
PSB Image B4 Spec:
Frequency Range
On Axis @ 0° ±1.5dB   70-20,000Hz
On Axis @ 0° ±3dB   60-23,000Hz
Off Axis @ 30° ±3dB   70-10,000Hz
Lf Cutoff -10dB   55Hz
Sensitivity
1w (2.83V) @ 1m, IEC-filtered Pink Noise, C-weighted
Anechoic Chamber   85dB
Typical Listening Room   87dB
Impedence
Nominal   6 Ohms
Minimum   4 Ohms
Input Power
RMS, Clipping < 10% of the Time
Recommended   10 - 80 Watts
Program   60 Watts
Acoustic Design
Tweeter (Nominal) 1” (25mm) Titanium Dome with Ferrofluid Neodymium Magnet
Woofer (Nominal)   4” (102mm)Clay/Ceramic filled Polypropylene Cone, Rubber Surround
Crossover   2,200Hz, LR4
Internal Volume Design Type   0.11 cu ft (3.1L)
Bass Reflex
« Last Edit: 17 Jun 2010, 02:24 am by chaosteo »
chaosteo
I got very timely response from Corey of Audioadvisor on speakers alone =)
"The PSB have better clarity and detail.  The Audio Engine P4 has a little stronger bass response, with a little warmer sound. Overall,  I consider the PSB speakers to be more accurate, but they are both fun to listen to."
Appreciated for other opinions.
saisunil
I have heard audio engine in show setting - I really loved them - very well balanced - you do not need a sub ...
PhishPhan
Nuforce S-1; killer speaker, but not for the bass addicts unless you're using 'em with a sub.
chaosteo
Yeah. I considred S-1 and the price is a steal. But it doesn't work with Icon Amp if I am not mistaken since I wanna use Amp to power other speakers down the road if possible.
