What Speaker cables and i/c ?
0 Members and 1 Guest are viewing this topic. Read 8743 times.
vegasdave
Re: What Speaker cables and i/c ?
« Reply #40 on: 5 Jun 2010, 11:43 pm »
I wonder if Walmart sells them.......
haha.
Stu Pitt
« Reply #41 on: 6 Jun 2010, 02:53 am »
Stuff like the cable elevators and the de-magnetizer are proof that people have more money than common sense.  I can't say they don't work, because I haven't tried them.  But seriously?  Wouldn't any non-conductive or isolating or whatever the term is material work just the same?
It doesn't end there - CD cutters, absurdly expensive CD cleaning machines and fluids, the Shakti room optomizer, high end equipment racks, and on and on.
I've heard differences in cables.  Not debating that at all.  But some of the prices and claims are way over the top.
vegasdave
« Reply #42 on: 6 Jun 2010, 05:21 am »
I agree.
Elizabeth
« Reply #43 on: 6 Jun 2010, 10:48 am »
For cables I use mostly Kimber: Hero, KCAG, 8TC.
I had some B&W 805s and now use Magnepan 3.6's with my Bryston gear.
PS: raising cables off the floor may have some benefit.
The original idea credit should go the Enid Lumley of Absolute Sound fame.
The cost of raising them can range from ZERO: I have used paper towel tubes wrapped in packing tape cut into 1" sections, works well, cost nearly zero.
 to really insane prices for exotic wierd stuff that STILL just holds the cable a bit off the floor.
I suppose if one has $15,000. cables, spending a few hundred for risers is OK.
vegasdave
« Reply #44 on: 6 Jun 2010, 10:28 pm »
I've seen styrofoam cups used as cable elevators!
Ryanz
« Reply #45 on: 7 Jun 2010, 01:01 am »
Since you can't recycle styrofoam, that's actually a darn good idea. Reduce, reuse, recycle.  :thumb:
vegasdave
« Reply #46 on: 7 Jun 2010, 01:17 am »
I guess so!
werd
« Reply #47 on: 7 Jun 2010, 01:22 am »
Of course, they reduce vibration also. No point in spending thousands on a stand and neglect cabling isolation.
Napalm
« Reply #48 on: 7 Jun 2010, 01:27 am »
Of course, they reduce vibration also. No point in spending thousands a stand and neglect cabling isolation.
The cure to all your "problems", real or imaginary. Made in Canada. 8 gauge. Good price:
http://www.homedepot.ca/webapp/wcs/stores/servlet/CatalogSearchResultView?D=908356&Ntt=908356&catalogId=10051&langId=-15&storeId=10051&Dx=mode+matchallpartial&Ntx=mode+matchall&recN=173135&N=0&Ntk=P_PartNumber
Nap.  :thumb:
werd
Napalm
« Reply #50 on: 7 Jun 2010, 01:33 am »
gauranteed... that stuff will resonate
Since you mentioned this.... are you an accomplished audiophile? i.e. did you fill your turntable with plasticine and your amp with sand?
Nap.  :thumb:
werd
« Reply #51 on: 7 Jun 2010, 01:34 am »
Nap.  :thumb:
nope
Napalm
« Reply #52 on: 7 Jun 2010, 01:46 am »
nope
Then you have some very rewarding work waiting for you Werd....
Nap.  :eyebrows:
Deftone
« Reply #53 on: 7 Jun 2010, 07:30 pm »
Elizabeth,this i what i have in mind too- Hero interconnects with the 8TC,12TC and maybe the Bifocal XL.
Speedskater
  • Kevin
« Reply #54 on: 7 Jun 2010, 11:55 pm »
Budget speaker cable stand-offs.
Large budget speaker cable stand-offs.
Deftone
« Reply #55 on: 12 Jun 2010, 06:18 am »
Thought of getting the Kimber too.Will the 12TC and Hero be a good match.I have the 803s,805s and the HTM3s.Or should i just go for the 8TC and Hero.Thanks
