Boxing my Bugle
0 Members and 1 Guest are viewing this topic. Read 1943 times.
SamA
Boxing my Bugle
« on: 31 May 2010, 10:56 pm »
I'm under orders to clean up the music room and that would seem to imply putting my Bugle in a respectable project box - nice and neat.
I have a nice project box and RCA panel-mount jacks, but for the life of me I can't figure out how to mount the Bugle and power supply in this box. The only standoffs I can find are those at Radio Shack and they're 11/16 inch and won't work in my 2 3/8 inch box if I mount the Bugle on the lid and power supply on the bottom.
Suggestions appreciated.
SamA.
jcg0322
Re: Boxing my Bugle
« Reply #1 on: 7 Jun 2010, 12:30 am »
Digikey.com has every size standoff............(or almost)
Check it out
jusbe
    • vivo media
Re: Boxing my Bugle
« Reply #2 on: 13 Jun 2010, 11:18 am »
Is it possible to get cases for the Bugle and its power supply that match the (blue) case of the Piccolo?
Theo
Re: Boxing my Bugle
« Reply #3 on: 18 Jun 2010, 01:08 am »
The factory Piccolo uses painted Hammond case.  Hammond cases come in either black or unpainted aluminum.  You will have to paint it yourself.
