Review of the RMX's...
0 Members and 1 Guest are viewing this topic. Read 6993 times.
warnerwh
« Reply #20 on: 18 Feb 2004, 02:27 am »
John: Due to the fact you are writing something for a patent. I'd be sure that air=liquid. It is indeed a fluid, not a liquid.  This could possibly cause a problem with the patent(s). An attorney would be a good person to talk to if you're getting ready to set the world on fire and are investing significant money.  Good luck on that too.
John Casler
« Reply #21 on: 18 Feb 2004, 04:48 am »
Quote from: warnerwh
You are 100% correct and if I hadn't forgotten to take my Gingko Biloba this morning I would have not made that mistake. (Shades of Tyson's signature)
It is a "Fluid" not a "liquid".
My Bad!  (I always wanted to say that, but now never again :oops: )
ekovalsky
« Reply #22 on: 19 Feb 2004, 06:05 am »
Just realized today I've been listening to my system with inverted phase for the last six weeks.  The JRDG 302/4 has its XLR inputs wired with pin3 hot, unlike just about everything else (including my dCs Elgar Plus) which has pin2 hot.  I saw "non-inverting" in the owner manual and never bothered to look at the pin assignment.
 :oops:
So I've inverted phase on the Elgar Plus and everything sounds even better
 :lol:
Thanks to Horsehead for pointing this out to me
 :notworthy:
LAL
« Reply #23 on: 22 Feb 2004, 12:07 am »
Brian on "spikes"
Posted by Brian Cheney ( i ) on December 07, 2000 at 17:32:07:
In Reply to: Do spikes couple or decouple the speaker from the floor? posted by phenderson on December 07, 2000 at 17:20:14:
Spikes both couple and decouple the cabinet/speaker output from the floor.
Bass wavelengths are quite long and, below about 200Hz, boundary dependent. Without a surface to travel along they dissipate somewhat rapidly. A woofer would ideally be as close to a boundary (floor) or multiple boundaries (side and back walls, and even ceiling) as possible, or at least a constant distance from them. By elevating a cabinet from the floor with spikes, you reduce the propagation efficiency of bass wavelengths. So, you decouple bass from the room, even if ever so slightly. The effect is quite audible.
Spikes couple cabinet output to the floor, turning it into a transmission medium. Soundwaves travel through many solids much more rapidly than through the air. Instead of "moving the floor", cabinet output is transmitted to the listener ahead of the music, through the floor (made usually a good carrier of sound like wood or stone). This is why I'm no fan of spikes, and the Sunfire people aren't either.
Big B
Posted by Brian Cheney ( i ) on December 07, 2000 at 19:38:30:
In Reply to: Re: Do spikes couple or decouple the speaker from the floor? posted by R. Hertz on December 07, 2000 at 18:25:40:
Since spikes do two things I don't like--diminish bass propagation, and transmit or even amplify spurious cabinet talk--I never recommend their use.
Big B
Posted by Brian Cheney ( i ) on December 08, 2000 at 07:50:00:
In Reply to: Re: This doesn't tie in with my experience posted by Steve on December 08, 2000 at 03:00:48:
As Sunfire recommends, rubber or other absorbent materials can be used as feet for speakers or subs.
Brian
