0 Members and 1 Guest are viewing this topic. Read 3423 times.
What should I look for at the local fabric store to cover the compressed fiberglass panels I'm building?
You can get fabric at places like:http://www.atsacoustics.com/cat--Fabric--107.html
In most rooms, broadband bass control is the thing that's needed most. Corners tend to be a very efficient place to put them as they're at the end of multiple room dimensions. The next thing to address is reflections on the side walls - especially if you're out of symmetry left to right in front of your seating position. Without knowing the room size, shape, setup, it's hard to say what and how much would be required. If you can post a pic or 2 or a rough sketch of the room, that would help a lot.Bryan
