Recommend a USB to AES converter
0 Members and 1 Guest are viewing this topic. Read 2823 times.
jtwrace
    • TIPP YouTube Channel
« on: 14 May 2010, 12:02 am »
That's right!  I have an idea and am looking for one.  The HagUsb seems very well priced but how does it perform?  What others should I look at?  I can use any type of input but would think AES is probably far superior.
Crimson
Re: Recommend a USB to AES converter
« Reply #1 on: 14 May 2010, 12:26 am »
I used a HagUSB for coax at one time but hadn't compared it to anything else. How about the Empirical Offramp?
jtwrace
« Reply #2 on: 14 May 2010, 12:28 am »
I thought about it until I saw the cost...chances are this will only be an experiment.  My Wavelength Crimson I don't think will be replaced.  Not anytime soon...
WGH
« Reply #3 on: 14 May 2010, 02:08 am »
I think the HagUSB performs very well, I have been using one for years. A few AC members have been over and liked what they heard. The output of the HagUSB is S/PDIF but maybe it can be modified, only Jim would know.
Do the wiring below in reverse? I dunno.
From Sound on Sound:
"However, although it is a rather makeshift solution (a 'bodge', to use the technical term), if you only need the signal to travel a fairly short distance — say, no more than two metres — you can get an AES output to feed an S/PDIF input with just a simple XLR-to-phono cable. Wire pin 2 of the XLR to the tip of the RCA phono jack, and pin 3 of the XLR to the sleeve of the phono. Pin 1 of the XLR should remain wired to the cable screen at the XLR end, but leave it disconnected and insulated at the phono end.
Strictly speaking, the Channel Status and other subcode data is formatted differently between AES and S/PDIF, but very little equipment bothers to send or read the full subcode data set anyway, so it is rarely a problem."
jtwrace
« Reply #4 on: 14 May 2010, 11:26 am »
That's good to hear.
It appears that Jim makes a AES version.  See here http://hagtech.com/hagusb.html
WGH
« Reply #5 on: 14 May 2010, 03:02 pm »
Nice! That version was not available when I got mine.
werd
« Reply #6 on: 14 May 2010, 03:17 pm »
Jtwrace
You should buy that one that for sale on the trade board here. The offramp turbo 2. It looks like the aes is hardwired out. Looks nice.
jtwrace
« Reply #7 on: 14 May 2010, 03:18 pm »
Jtwrace
Yeah.  Just a bit more then I wanted to spend.
werd
« Reply #8 on: 14 May 2010, 03:23 pm »
How about the thingy by blue circle... dont know if it does 24 bit though.  :scratch:
