0 Members and 1 Guest are viewing this topic. Read 181057 times.
THD at 13 watts output into 8R (+20dBU) simulates at 0.026% - quite high, in fact, but fantastically over 85% of this figure is second harmonic only!! All the odd order distortions are vanishingly low; the highest is third harmonic, which sounds pretty good because it's musical, and it's at -106dB, with all successive odd orders much lower than this!! These are stunning technical results, even if we ignore the subjective sound quality, which is surreal.
Seano,Hi Russ here, I will comment as I have just had a LF55 (modded with upgraded input caps etc) and I can tell you the Naksa is a significant and obvious step up. It has a clarity, warmth, musicality, transparency, bass extension and clear top end especially with vocals and strings that the LF55 could not approach. The Naksa has no trouble driving the vsonics to unlistenable volumes. Having also heard the Soraya in a few iterations, to my ears the Naksa is a much more "analog" (smooth), detailed and musical amp than the Soraya. I am compiling a few more comprehensive notes on the Naksa but I struggle to hear any downside at the moment compared to the LF, I will admit to being more interested in music than audio equipment but will see how I go. If you are in Melbourne feel free to pm me for a listen.Russ
Hugh.....just to seek a little bit of clarity here....you would consider the NAKSA as an upgrade to the ye olde AKSA55 and its variants, LF55 and (perhaps) the 100w versions of the same? If yes.....in what way - apart of course from dollars?
Truth is my notions are sufficiently heretic for me to be darkly regarded as a quack. I have been roundly accused of 'technical incompetence' on DIYaudio several times by the maths gifted experts of yore. Tragically, none of these guys have heard my amps, ain't life grand? But as Groucho said, 'I would never be a member of a club that would have me as a member.'
Knowing that you belong proudly to the solar plexus school of audio...
I do tend to tilt at windmills, product of a thin skin I guess, so I tend to forget that not all are adversaries, so my apologies to you and any other benign Mathematicians I have foolishly scorned. A late friend (very sad, dead of multiple myeloma at 60) once said 'Hugh is much more the engineer than he would have you believe'. The odd thing is that my great love is for the laws of Georg Simon Ohm and Gustav Robert Kirchhoff and these underpin all I know of electronics. The rest, pretty much, is based on intuition.... and a helluva lot of dead semis, with the smoke long since dissipated...... 'You learn nothing of electronics until you traipse daily through the silicon crematorium, and can recite all the tombstones by rote' - Hugh, 1997.
