ST-100 Speaker Wire for Maestro XL subwoofer
djost
« on: 7 May 2010, 09:14 pm »
I have a Maestro XL subwoofer and would like to get a longer speaker cable that goes from the subamp to the subwoofer.  I believe a "run" of ST-100 came with the sub, but I need a longer length.  Can I buy some ST-100 from the ACI website ?  If not, what else would folks recommend ?
Doug
Joe_K
Re: ST-100 Speaker Wire for Maestro XL subwoofer
« Reply #1 on: 8 May 2010, 12:41 am »
Hi Doug,
If they're not selling it, I have some I bought and haven't used.
What length are you looking for?
Joe
djost
« Reply #2 on: 8 May 2010, 02:05 am »
Hi Joe,
I need ~20ft.  Will make a more exact measurement in the morning.  The ACI website appears to let one place an order for ST-100 cable, but unless I get a response stating it will be honored, I'm not going to place an order.
Thank you for the reply.
Doug
jparkhur
« Reply #3 on: 9 May 2010, 01:13 am »
ACI is still taking orders for DH Labs wire.  Mike will have it shipped directly from them.
djost
« Reply #4 on: 9 May 2010, 01:24 am »
JP -
Thank you for the reply.  Will go ahead and place order via ACI website.
Doug
