Moving to Server based Music
0 Members and 1 Guest are viewing this topic. Read 2993 times.
Eric
« on: 7 May 2010, 01:51 pm »
I just purchased a MAC iBook Pro. If I wanted to migrate to a server type playback system, what are the steps? I would like to place all my current CD's and SACD's on the server as well as be able to download high res stuff
ted_b
Re: Moving to Server based Music
« Reply #1 on: 7 May 2010, 02:34 pm »
This is likely to get way more hits and experienced stories over on the Apple Core Circle.  Also, SACD's cannot be ripped for hard drive use unless you have sophisticated DSD-to_PCM capabilities or a specifically modded SACD player that takes the downrez'd PCM and outputs to modded digital outs.  So, net/net, the only SACD you'll get is the redbook layer.  DVD-Audio, on the other hand, is easy.  My HiRez Circle has tutorials.
Get a good disc transport for ripping.
Eric
« Reply #2 on: 7 May 2010, 04:26 pm »
Thanks, bro
audioengr
« Reply #3 on: 9 May 2010, 12:39 am »
Ripping is critical.  The best ripper I have found is DBpoweramp on a PC.  I rip using a Teac USB drive and then transport the .wave files to the Mac.  You lose tagging, but the quality is the best.
If you are willing to sacrifice a bit of quality, then rip to AIFF using iTunes.  This will maintain the tags.
Once everything is ripped, you will need a good D/A and some type of converter, USB, WiFi or Firewire.  Sometimes these are built-into the DAC, but this generally sacrifices some quality.
Playback should be iTunes combined with Amarra or Pure Vinyl playback software.
If cost is no object, then I recommend the Pace-Car USB with Ultraclocks driving a Overdrive DAC using I2S interface cable and then XLR cables driving your amps directly.  Several customers have told me that this beats their megabuck vinyl setups.
Steve N.
Newk Yuler
« Reply #4 on: 9 May 2010, 04:38 am »
Folks interested in dBpoweramp and the Teac drive Steve's talking about should look at this thread:
http://www.audiocircle.com/index.php?topic=68223.0
skunark
« Reply #5 on: 9 May 2010, 05:17 am »
For a mac you can use Max to rip the CDs:
http://sbooth.org/Max/
It does the checksum thing that the others EAC and DBpoweramp will do.  You can point the output to "Music/iTunes/iTunes Music/Automatically Add to iTunes" folder if all you end up doing is CDs.  For hi-rez playback you can use http://cogx.org/ it will do Flac, WAV, Apple Lossless etc, but it doesn't seem to select the correct settings yet for the audio output.   There are other solutions to, which the you can discover in the apple circle.
I typically keep the software light though and stick with open source products, perhaps when more hi-rez tunes become available and when a truly major record label decides on a file format I might pick a better solution.
audioengr
« Reply #6 on: 9 May 2010, 06:11 pm »
does Max use Accurate-Rip?
Steve N.
ted_b
« Reply #7 on: 9 May 2010, 06:26 pm »
Steve N.
I don't think so.  I use same reasoning as Steve:
* use best ripper you can find (DBpoweramp or EAC, both Windows-based)
* move files to MAC (I also use WAV as I find it sonically more musical, then go through the Geoff's (Silverlight) documented steps to preserve metadata on MAC iTunes with PM or Amarra)
Edit:  Supposedly XLD is a MAC-based ripper with Accuraterip capabilities.
http://tmkk.hp.infoseek.co.jp/xld/index_e.html
fu_man
« Reply #8 on: 10 May 2010, 09:17 am »
Does  PM = Pure Music , a cheaper  'version' of  pure vinyl?. Is  it  just a s  good as a player if we are not concerned  with ripping vinyl?
ted_b
« Reply #9 on: 10 May 2010, 01:23 pm »
Yes, same engine.
