0 Members and 1 Guest are viewing this topic. Read 29219 times.
Steve, see my take on Matrix mini-i on this site comparing to MF v-dac, those are the onlu two i have tried, head fi has so many postings on this stuff it is overwhelming.
This is an upsampling DAC, correct?
I've been interested in this DAC http://cgi.ebay.com/24bit-192KHz-DAC-DIY-KIT-FULL-ASSEMBLED-KIT-Lampucera-/120551270538?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item1c116a688a It's getting positive reviews on DIY Audio http://www.diyaudio.com/forums/digital-line-level/164299-new-small-diy-gigawork-dac-2.htmlIt's DIY but it comes all wired together. You could put it in a shoe box.
The HRT Streamer USB DACs are getting fantastic reviews. At $350 you could get the Streamer II+. When I talked to HRT about their new line of DACs, they told me that the new non-+ version of the Streamer II was a better choice than the original Streamer+. The II serives now has async USB and can handle hi-rez. MusicDirect carries them, so you could take advantage of their 30-day trial period.Lots of great reviews of the original lines and the new streamer. Check the spinoff of the DAC shootout thread here, and 6moons for starters.
Thats cool about HRT but for me-"Good but cheap.." means under $200....the gigaworks looks cool but I have no equipment or ability at even one solder joint. I checked with whoever it is that is Gigaworks and asked about a fully assembled one in a case like ready to go and they offer it....I'll dig up the info..if I remember correctly it was around $150..not positive on that.
In a related search...We are looking for a reasonably priced D/A with balanced outputs and a level control . Price target is <$600 street. We can go a bit higher if necessary. Any recommendations???The idea is for preamp-less complete system driven by Apple Lossless tracks on iPod into a Wadia dock, so coax S/PDIF is also required. The Wadia unit has no TOSLINK or AES/EBU (AES3). Related post:http://www.audiocircle.com/index.php?topic=58526.msg730574#msg730574
On the Giga DAC assembled kit, where is the ac power? Kit list: The kit contents - 1. Main DAC board. Size 80mm(D) X 55mm(W) X 25mm(H)2. Power supply board Size 80mm(D) X 55mm(W) X 40mm(H)2. Come with High quality Encapsulated Power Transformers x1pcs ( 110V or 220V )4. IEC AC socket x1pcs5. Connection cables Features -1) 4 separated individual precision voltage regulator.2) High precision 1% metal film SMD resistors and metal capactors,3) High grade op-amp NE5532 x 3pcs for the output stage.4) A pair high quality RCA sockets for analog output.5) On board jumper to select the digital input ( coaxial or optical ).6) High quality ELNA and WIMA capacitors. Audio Specifications:Digital / Analog converters: PCM1798 (24bit 192khz DAC) (Old version use CS4397)Digital receiver : Crystal CS8416Master clock jitter: below measurable levelsDigital input: Coaxial and OpticalAnalog output: RCA 2V rms. @75 ohms If I'm assuming correctly it would just need a typical ac cord like a desktop PC or monitor uses???
http://cgi.ebay.com/Mini1543-DAC-TDA1543-DIR9001-NOS-DAC-Kit-Board-/290405888644#ht_2423wt_939Another I found, that looks like it could use same Parts Express PS that powers my SB...This is Cheap, got some good comments on DIY, I wanna build one, need a project...just thinking out/typing..
Bunnyman357 had recommended this unit:http://pro-audio.musiciansfriend.com/product/TC-Electronic-Impact-Twin-Next-Generation-FireWire-Interface?sku=584562Would that work?
The Music Hall dac 25.2 has a level control and differential balanced solid state outputs (although its 6922 tube output is single ended). It uses the TI PCM 1796 24bit/192kHz DAC. It sells new for $595. Steve
