Question for James "B60 jumpers"
0 Members and 1 Guest are viewing this topic. Read 1490 times.
rob80b
« on: 5 May 2010, 09:16 pm »
Hi James
We're discussing alternative connections between the pre/amp on the B60, do you know if the jumpers are copper or steel under the gold platting?
http://www.audiocircle.com/index.php?topic=80781.0
Robert
  • The Demo is Everything!
    • http://www.bryston.com
Re: Question for James "B60 jumpers"
« Reply #1 on: 5 May 2010, 10:48 pm »
Hi James
Robert
Hi Robert - not sure - I will check.
james
« Reply #2 on: 6 May 2010, 02:47 pm »
Hi James
Robert
Engineering - tells me the jumpers are gold plated brass.
james
rob80b
« Reply #3 on: 6 May 2010, 03:25 pm »
Thanks James.
