Then this is the one I'm getting: 8R15W-I (#002-00713) - $229.00 - 20% = $184.00 How can you beat that!!??
That's less than I paid for my 4 outlet Duet.Martin
It's pretty incredible deal and it's one of the best surge protectors out there. The one I listed is rated for 15amps and has isolated outlets. A+
Unless it's for a computer/server that needs to have limited downtime.
When I worked in IT, we used to recommend the APC products.
Tell me more about your situation. UPS units are either cheap and useless (nothing special), or extremely expensive and complicated for serious information protection.
Just follow this step-by-step and it will give you a recommendation at the end: http://www.cdw.com/webcontent/promos/landing/power_protect_new.asp
Nagy-One more thing. If you want the very best power filter that I've used, get an UberBuss or MuthaBuss as I have. Dave (dbe) from PI Audio make them. http://www.audiocircle.com/index.php?topic=68006.0http://www.audiocircle.com/index.php?topic=78133.0
I don't believe those are $200 or less. (Not my criterion -- the OP's.)
