ob servo subs
0 Members and 1 Guest are viewing this topic. Read 1836 times.
[email protected]
ob servo subs
« on: 5 May 2010, 12:50 pm »
What are the benifets or drawbacks of the two differant types of cabinets for the ob servo subs? I've seen people build them in the h-frame and the w-frame. This sub will be used for mostly 2 channel along with a set of ob 7's. It will do some 5.1 duty. these will be paired with an emo,umc1and an ips1.
thank
marty
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
Re: ob servo subs
« Reply #1 on: 5 May 2010, 01:27 pm »
Height and width differences mainly
Voiceray
Re: ob servo subs
« Reply #2 on: 5 May 2010, 10:56 pm »
thank
marty
Resonance Issue
But probably not with the plan at 80 Hz.
Here is an old discussion on it.
http://www.audiocircle.com/index.php?topic=54875.0
Danny Richie
Re: ob servo subs
« Reply #3 on: 7 May 2010, 01:19 am »
The H frame breaks it up better with bracing as the baffle is right up the center.
The W frame has slightly larger diagonal areas and the whole top that can't be braced.
And yes these woofer do put some pressure on the side panels.
