Thanks. I saw your link on removing the smartware on WD drives, but my understanding is that only disables the software. You can't delete it from the HD. But I guess if it is quiet and reliable, I might bite the bullet and get WD drive.What is your opinion on the OWC drives? Seems well built.
Bimopti, thanks for suggesting the singlestack drives buy I'm not sure which model you are referring to. Can you give me the link to the drive you are talkin about? Do you own one of hthem?
