9B-ST power frequency hum
0 Members and 1 Guest are viewing this topic. Read 3270 times.
thomaspf
« on: 9 Feb 2004, 12:56 am »
Hi,
I am rearranging my system and would like to get rid of an annoyance in my setup. I do have a SP1.7 hooked up with balanced cables to my 9B-ST. They are both plugged into the same wall dual power outlet. The active subwoofer is plugged in the SP1.7 via balanced cable but unplugging it does not make a difference.
When I power up the system and the SP1.7  comes I get a rather loud ground loop hum emitting from the 9B-ST chassis. I can play a stream of zeros at 0db and the signal is almost free of ground noise but the ampifier is physically vibrating. When I turn the SP1.7 off it makes no noise whatsoever.
What should I try to get this under control. The hum is very audible from my listening poition and somehow defeats the black background coming from this amp otherwise.
I read that the 9B-SST has upgraded grounding. Is this a known problem that was addressed in the upgrade from ST to SST?
Any help is appreciated.
Cheers
   Thomas
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 9 Feb 2004, 02:39 am »
Hi Thomas,
Do you mean you hear hum from the amp as if the transformers are buzzing or hum through the speakers?
james
thomaspf
« Reply #2 on: 9 Feb 2004, 03:16 am »
Transformers are buzzing loud and audible.
Very low hum in the signal if I record it and run a fourier analysis over it.
Any thoughts?
Cheers
Levi
Hummm
« Reply #3 on: 9 Feb 2004, 03:52 am »
Sounds like you have a line noise problem.  Sometimes dimmers does that.  I once heard that sound coming from the amp and it is annoying.  It just misterously disappeared one day.  huh.
« Reply #4 on: 9 Feb 2004, 12:26 pm »
HI Thomas,
I agree it sounds like noise on the power line rather than the amplifier. The amplifier has 5 independent transformers so the chances of them all be bad is not likely.
james
lowrider
    • DIY
« Reply #5 on: 9 Feb 2004, 01:54 pm »
The same happened to me when I added a second power to my system, had to disconect the ground in the wall socket or the PCs, no more hum...
I dont know if it is safe or not, I had it this way for over 2 years without any problem...  :roll:
thomaspf
« Reply #6 on: 9 Feb 2004, 07:41 pm »
O well,
I will try the cable without ground connected first. Probably won't pass any inspection.
Cheers
   Thomas
jethro
« Reply #7 on: 9 Feb 2004, 10:25 pm »
Those tall halogen "Torchiere" floorstanding lights can cause problems as well. The toroidal  transformer of my H/K AVR-7000 would buzz loudly (mechanical buzz) when the lamp was on. Moving the lamp to the other end of the house and on a separate circuit only slightly improved the buzz. The lamps are kind of dangerous so I didn't feel too badly turfing the lamp.
thomaspf
« Reply #8 on: 10 Feb 2004, 12:14 am »
The only other equipment I turn on for the hum to appear is the SP1.7 which is connected via Bryston balanced cables.
It would be kind of sad if they don't get along. When I turn off the SP1.7 and connect a different source to the amp directly there is no hum.
I found a spare cable and will try the hooking it up without grounding tonight.
Cheers
   Thomas
thomaspf
« Reply #9 on: 10 Feb 2004, 03:54 am »
I clipped the grounding pin off the spare power cable and replaced the factory power cable on the 9B-ST with it.
There is no difference in the hum with or without ground connected, so let's look at other possibilities.
My start switch stopped working a while ago and I plug and unplug the amp to turn it on or off. Could that have an impact?
Any other recommendations?
Cheers
    Thomas
