I put mine underneath the charocal--works faster than on top
jtwrace,If you turn the Traeger up all the way it will come up to 500 degrees in about 20 min.
alright alright. You're right. I'm wrong and you're right. Yes, even you Ruby.
Ed, have you tried an electric starter? Just stick it under a pile of charcoal, plug it in and remove it in about 15 minutes. I found it easier to use than the flue approach
Just got my June 2010 issue of Consumer Reports today, and lo and behold they rate gas grills. Four recommended models under $380.00.
I have a Lynx stainless steel, solid brass burners, propane, 10+ years old replaced rocks once still as good as new.
Hi VL,I have owed a couple of the electric starters throughout the years. In my situation I would have to drag out an extension cord to get the electric unit going. Easiest for me has been the flue, to each his/her own!Best,ed
