Which BBQ Grill to purchase?
0 Members and 1 Guest are viewing this topic. Read 35462 times.
jtwrace
    • TIPP YouTube Channel
Re: Which BBQ Grill to purchase?
« Reply #120 on: 23 Jun 2010, 03:17 pm »
jtwrace - Thanks for starting this topic.
You're welcome!   :thumb:
jtwrace
« Reply #121 on: 12 Jul 2010, 01:27 am »
Just an update on how much I'm lovin' my Grilldome.
A LOT!!!
taoggniklat
« Reply #122 on: 11 Nov 2010, 03:34 pm »
I love my weber kettles (22, 18 and 14) and my 55 gallon smoker. Nothing fancy but they work.
Sure gas is convenient but honestly, with a charcoal chimney starter, it really only takes 10-15 minutes for the coals. I have done everything from pulled pork, chicken, turkey, ribs, burgers, shrimp, stuffed bell peppers on my weber.
Mike Nomad
« Reply #123 on: 11 Nov 2010, 04:19 pm »
« Last Edit: 18 Nov 2014, 10:40 pm by Mike Nomad »
werd
« Reply #124 on: 13 Jul 2011, 05:36 pm »
Just a tip on barbies. If buying a new barbie look for ones that let you take the flame tubes out easily. Avoid the ones that are screwed into the barbie. I need to clean my tubes on a Char broil and they are screwed in. The screws are not turnable due to corrosion, so i have to cut them off. There is also one screw that attaches the igniter that is behind the front plate so i have to do a  dissemble to do this  :(
Wig
« Reply #125 on: 13 Jul 2011, 05:39 pm »
I have a Primo XL Oval and love it. This the best grill I have owned and have had many....
Wig :thumb:
