0 Members and 1 Guest are viewing this topic. Read 17157 times.
I have some updates on Touch mods. I will be cross posting on a couple of threads about this.I have finally completed the first digital output mod for the Touch and it IS quite a bit better than the stock Touch into the modded EE DAC.Noise floor is lowered. Soundstage is wider. The image is more defined. Dynamics, both micro and macro are improved.While listening to this modded unit, I compared it to my slightly modded Touch and my Enthusiast Plus modded DUET. The modded DUET sounds very close to the same level mod done to the SB3. The SB3 is a bit noisier because of the display.Ranking the sound of the three units on DIGITAL output to the EE DAC, The digital modded Touch sounds the best. Next is the digital modded DUET. Then the stock Touch.All of these were used with BOLDER linear PS. I used both Touch with my older Ultimate MKIII PS and a newer PS design that I will be offering called simply the Deluxe PS. It uses a feed forward shunt pre-regulator to reduce line noise. It does run on the hot side, but it does sound better than the older Ultimate MKIII. The Deluxe will be selling for $750.00. The same circuit will be offered with Jensen caps as the Ultimate MKV.The DUET used my Standard PS. My conclusions are: if you do not intend to use 24/96 files, use a Enthusiast Plus modded DUET or SB3 with one of my linear PS to get the most out of your music. It you do plan to use 24/96 or just want the best sound possible, go for the Touch with digital mods and a Deluxe PS. The digital modded Touch does sound better than the digital modded DUET on both standard res and 24/96.
As far as high end, price no object, the Touch will fall short. At this point it is limited to 24/96. I have heard some of the very few Reference Recordings albums at higher sampling rates. They do sound better, without a doubt. There are maybe a dozen readily available recordings in this format. Perhaps, in time, there will be more. Perhaps the Touch will be able to play these recordings back in their native format. But for now, the Touch falls just a bit shy of the ultimate digital playback.
Wayne just starting to experiement with my new Touch. I tried playing a few hirez files above 24/96 and they would not even play, is that because sox wasnt enabled? Or can the Touch not even play anything above 24/96. When you said the higher sampling rates do sound better, were you refering to being played through the Touch? Thanks...
