Cheap cable/power cord management....
0 Members and 1 Guest are viewing this topic. Read 2188 times.
Wayner
« on: 29 Apr 2010, 03:36 pm »
I had some left over sump-pump tubing from my recent home improvement project, and was going to throw the left overs away, then the idea hit me.
24 feet of tubing for about $12 is 50 cents a foot. I used about 6" for this cord. Pretty cheap and does the job.
Wayner  :D
Re: Cheap cable/power cord management....
« Reply #1 on: 29 Apr 2010, 04:14 pm »
Slick Wayner. Simple, effective, & inexpensive. Better get your patent before some monster comes along and lays claim to the idea.   :D
Wayner
« Reply #2 on: 29 Apr 2010, 09:32 pm »
Well, publishing it on the internet already gives me some copyright protection.
W
decal
« Reply #3 on: 29 Apr 2010, 11:00 pm »
Now Wayner,you know good and well that coiling up that power cable will induce eddy currents that will destroy your sound!!!!!!!!  :lol:
Listens2tubes
« Reply #4 on: 29 Apr 2010, 11:18 pm »
Funny I was shown this using toilet tissue tubes to store extension cords. My friend told me his grandmother had shown him. :scratch:
« Last Edit: 30 Apr 2010, 02:27 am by Listens2tubes »
K Shep
« Reply #5 on: 29 Apr 2010, 11:44 pm »
How did you get the cord to match the tubing, color?  I had to double take after I read your post.  Good stuff!
avahifi
    • http://www.avahifi.com
« Reply #6 on: 5 May 2010, 02:05 pm »
The external wire coil wrapped around the power cord "might" act as a high frequency RFI filter and actually make the sound better.
Note that I said "might", then again, it might not.
Frank Van Alstine
srb
« Reply #7 on: 5 May 2010, 03:36 pm »
Although the photo looks like wire wrapped around the power cord (much like how factories wrap cords on small appliances, etc.), in reality it is a piece of plastic/rubber flex tubing.
Wayner
« Reply #8 on: 5 May 2010, 03:57 pm »
It's 1 1/4" sump pump tubing.
W
mark funk
« Reply #9 on: 5 May 2010, 08:00 pm »
Yes, I had to look twice, I thought that was cord too but it is tubing the same color as the cord  :o.
        :smoke:
