RM40 FAQ
0 Members and 1 Guest are viewing this topic. Read 16084 times.
SpeakerDoc
Re: RM40 FAQ
« Reply #60 on: 19 Aug 2010, 07:07 pm »
Unless the tweeter has a bad transformer you don't need to replace it.  The foam pads are no longer available, we have slotted masks now.  These are $12pr plus $3 shipping.
We don't have any faceplates for the ribbon tweeters on hand, unfortunately.
Do you have any suggestions for testing/confiming that the FST tweeter
transformer is in proper working order?  Primary and secondary DC resistance
perhaps to start?  I know there is much more to it but this would be a start.
SpeakerDoc
Re: RM40 FAQ
« Reply #61 on: 23 Aug 2010, 03:45 am »
Brian Cheney
    • http://www.vmpsaudio.com
Re: RM40 FAQ
« Reply #62 on: 23 Aug 2010, 04:32 am »
If both tweeters sound the same and play at the same level with a given input, they're OK.  Bad transformers usually give you low output levels.
SpeakerDoc
Re: RM40 FAQ
« Reply #63 on: 23 Aug 2010, 03:09 pm »
So these have the mega woofers, and I read here where Brian states that the "mid-woofer upgrade"
requires an additional cap:
http://www.audiocircle.com/index.php?topic=60430.msg538924#msg538924
"The crossovers require an additional cap when the midwoofer upgrade is done. "
I just want to confirm that the crossover is correct for the mega mid-woofer, it has a series C,
shunt L, L-Pad, then a series L, no second cap.
Do I need to add a cap?
