Industry Circles
GR Research
Danny Richie
N2x with Vintage electronics?
0 Members and 1 Guest are viewing this topic. Read 1081 times.
monkeypimp
27 Apr 2010, 05:22 pm »
Long story short...I am doing my office totally retro with the exception of my computer and N2x speakers....I want to do a vintage setup for the n2x's...can anyone tell me if an old Marantz 140 amp and Marantz 3002 preamp would work well with the N2X's? The pic shows the Tuner which I won't be getting right away until I would be able to track one down.
Marantz 140
Specifications:
Power Output: 75 Watts per channel RMS into 8 ohms
Power Band: 20Hz to 20kHz
Total Harmonic Distortion: 0.1%
Input Sensitivity: 1.5V for Rated Power Output
Frequency Response: Within +/- 0.25dB at 1 Watt
Intermodulation Distortion: Less than 0.15% at Rated Power Output
Damping Factor: Greater than 30 into 8 ohm
Total Noise from Input to Output: -98dB
Marantz 3200
Specifications:
Output Voltage at Rated THD: 3 Volts
Rated THD at 1kHz: 0.05%classicaudio.com
Maximum Output Voltage: 7 Volts at 1.0% THD
Frequency Response: PHONO: 30-15kHz, AUX: 20-20kHz
Wood Case Accessory: WC10Uclassicaudio.com
Controls:
Selector: Phono 2, Phono 1, Tuner, Aux, Tape 1, Tape 2.
Tone Mode: Out, In, 250Hz, 4kHz, 250Hz/4kHzclassicaudio.com
Bass: (Slider)
Mid: (Slider)
Treble:(Slider)classicaudio.com
Mode: Left, Right, Stereo, Reverse, Mono L+R
Volume
Balance: Slider
jtwrace
Re: N2x with Vintage electronics?
27 Apr 2010, 05:24 pm »
I'm sure the monkeys won't mind being pimped with Marantz playing the tunes.
Industry Circles
GR Research
Danny Richie
