0 Members and 1 Guest are viewing this topic. Read 41778 times.
- Would prefer that it need need a mega wattage amp to sound its best
Just checking, I've never heard anyone say that they would prefer that a speaker needed a megawatt amp to sound its best. Are you sure you didn't mean to say "would prefer that it didn't need..."? Maybe that's what the first of the two needs was supposed to be. Steve
Thanks for catching that Steve. I made the correction.
While very good, Selah and Salk are typically in the mid 80's efficiency range, and therefore do not meet the last requirement.
A friend is searching for speakers (new or used) and I was curious what you guys would recommend.Here are a few parameters:- Recommendation must be full range (down to say 30Hz)- Must work in a living room (can't be way out into the room, six feet tall, etc...)- Must have good to very good WAF- Would prefer that it didn't need need a mega wattage amp to sound its best - Is willing to go the sat/sub route to achieve full rangeCompanies already on this person's radar screen:- Salk- Gedlee- Vandersteen- Devore- DynaudioThanks for your input.George
Given the budget, I thought he'd be shopping in the higher end Salk range, which I thought were all fairly inefficient. But I could be wrong.
