They're Aliiiive!! N3's in Cherry.
0 Members and 1 Guest are viewing this topic. Read 4881 times.
dvenardos
Re: They're Aliiiive!! N3's in Cherry.
« Reply #20 on: 25 Apr 2010, 03:03 am »
Yes.
Also, what did you use for cabinet treatment, ie No-Rez and...?
I will be using the No-Rez but I wasn't really thinking about stuffing it with poly fill or such. Should I?
Thx
Dave
Plund
« Reply #21 on: 25 Apr 2010, 02:10 pm »
Light-Echo Dave,  I used 1/2" MDF for both the baffle and the Grill.  The radius at the bottom of the baffle is 10".  Finished the baffle with six coats semi-gloss rattle-can Rustolium.  As for poly-fill stuffing, I used Acousta-stuf...placing it where Danny has indicated in the Spec sheet he included in the kit.  I used about 1/2 lb per speaker, maybe slightly less.
Danny,  thanks for the tip re: placing foam in the bottom of the port!  I built my N3's ported in the front because I needed to keep these somewhat close to the wall but now I see I have some 'sperimenting to do!
Plund
« Reply #22 on: 27 Apr 2010, 12:26 pm »
Congrats on your build!  They are very Beautiful!
We want pics from the side too!  :drool:
Thanks dgshtav.
dgshtav
« Reply #23 on: 28 Apr 2010, 02:17 am »
Thanks for posting the pics of the sides. Beautiful!
